truetype fonts problem...
korakas koarkis
korakas2004 at YAHOO.GR
Mon Dec 11 08:55:19 EST 2006
Hi Graham,
You have right I am using the iso8859 Greek arial font.
I try to use a copy form c:\windows\font the arial unicode ttf file but the problem remains ....
kio
Graham Berry at Virgin <g.berry at VIRGIN.NET> Ýãñáøå:
v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} Clean Clean DocumentEmail MicrosoftInternetExplorer4 st1\:*{behavior:url(#default#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
I have just solved the same problem and this is the snippet from my map file. You are probably aware that you need to be careful of the font you are using to old your data. If you are using iso8859-n (Greek) then you need a font with those characters in the upper 128 character positions. However if you are using UTF-8 encoding then use the arial.ttf font and you will get support for all/most of the iso8859-n range of character sets.
My next trick is to try the new �Arial Unicode ms� font for far east languages.
Hope this helps.
Graham Berry
gberry at qpqsoftware.com
MAP
 # Start of map file
 NAME "Bulgaria"
 STATUS ON
 EXTENT 22.097 44.508 28.857 40.653
 SIZE 500 500
 SHAPEPATH "shpdata"
 SYMBOLSET "symbols/symbols.sym"
 FONTSET "/htdocs/www/v2/map_bulgaria/symbols/fonts.txt"
 IMAGECOLOR 200 200 200
 UNITS DD
 # you may need to change this to match your MapServer build
 IMAGETYPE PNG
 # Start of web interface definition (including WMS enabling metadata)
 # Start of legend
 LEGEND
   STATUS ON
   KEYSIZE 18 12
   LABEL
     TYPE TRUETYPE
     FONT arial
     SIZE 10
     COLOR 0 0 138
   END
 END
 LAYER
   NAME "ZZ"
   STATUS DEFAULT
   TYPE POINT
   TOLERANCE 5
   CLASS
     NAME "##-##EditLocation"
     SYMBOL 4
     COLOR 0 0 0
     SIZE 8
     MINSIZE 1
     MAXSIZE 100
     LABEL
       TYPE TRUETYPE
       FONT arial
       SIZE 8
       POSITION AUTO
       COLOR 0 0 0
       OUTLINECOLOR 255 255 255
       PARTIALS FALSE
     END
   END
# INSERT EDIT LOCATION {Dynamic points added at runtime}
 END
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On Behalf Of korakas koarkis
Sent: 11 December 2006 11:58
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: [UMN_MAPSERVER-USERS] Î�Îμα: Re: [UMN_MAPSERVER-USERS] truetype fonts problem...
Thanks for the quick repsonses.
I used an absolute path to the fontset.txt:
arial C:\ms4w\Apache\htdocs\gp\font\arial.ttf
and in the map file I refer only to arial truetype fonts but the problem remains!
msGetLabelSize(): TrueType Font error. Requested font (arial) not found.
Also the arial.ttf file is a copy from the C:\windows\fonts directory so it is not corrupt..
kio
boice tomlin <boice at runskip.com> ÎγÏ�αÏ�ε:
Hello,
I would start by using an absolute path to the fontset.txt file to see if the relative path is the problem.
Then I would try using just one font in the list and see if you can get that working. If it can find the arial font but not the arialbd then maybe that font file is corrupt.
-boice
On Dec 8, 2006, at 12:02 PM, korakas koarkis wrote:
Hi all,
I want to use true type fonts in my maps and I am using the following setup:
a "font" folder with: arial.ttf arialbd.ttf.
also in this folder is placed the fontset.txt:
arial arial.ttf
arialbd arialbd.ttf
and finally in my map file
FONTSET "..\font\fontset.txt"
LABEL
TYPE truetype
FONT arialbd
SIZE 9
but the mapserver produces ::
msGetLabelSize(): TrueType Font error. Requested font (arialbd) not found.
I am completely stuck here.
The mapserver sees the fontset.txt, (if i rename it it produces an repsective error message) but it can not read the aliases!
kio
Χ�η�ιμο�οιεί�ε Yahoo!
Î�αÏ�εθÎ�καÏ�ε Ï�α ενοÏ�ληÏ�ικά μηνÏ� μαÏ�α (spam); Το Yahoo! Mail διαθÎÏ�ει Ï�ην καλÏ�Ï�εÏ�η δÏ�ναÏ�Î� Ï�Ï�οÏ�Ï�αÏ�ία καÏ�ά Ï�Ï�ν ενοÏ�ληÏ�ικÏ�ν μηνÏ�μάÏ�Ï�ν
http://login.yahoo.com/config/mail?.intl=gr
Run Skip
http://runskip.com/
boice tomlin
503-528-6204
Â
×ñçóéìïðïéåßôå Yahoo!
ÂáñåèÞêáôå ôá åíï÷ëçôéêÜ ìçíý ìáôá (spam); Ôï Yahoo! Mail äéáèÝôåé ôçí êáëýôåñç äõíáôÞ ðñïóôáóßá êáôÜ ôùí åíï÷ëçôéêþí ìçíõìÜôùí
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20061211/0d265532/attachment.html
