How to download the list-archive?
Pericles S. Nacionales naci0002 at UMN.EDU
Mon Dec 11 13:08:42 EST 2006
Roman, folks,
You can request a monthly "notebook" by sending a "get" command to
listserv.  Here's the syntax:
   get listname.LOGYYMM
where
listname=mailing list name (MAPSERVER-USERS),
YY=year
MM=month
For example, if you want the November notebook you'd send the following
command:
   get MAPSERVER-USERS.LOG0611
The list server well then mail it to you.  There might be other options
through the mailing list's web interface...
I hope that helps.  Good luck!
-Perry
Roman Meier wrote:
> Hi list
> I don't have a permanent internet connection. That's why I find it a bit
> difficult to search the archive online using a webbrowser. You changed your
> listsystem to listserv in 2004. Since then I can't download the monthly
> archive, because the links an not available anymore. I used to do that
> regularly. Like that I could search the archive offline, because I had a copy
> of the hole archive on my pc.
> How can I download and read the archive offline?
> Thanks for your help…
> Roman
