use of strict xhtml for the html templatefile
Andy Freed
afreed at PDX.EDU
Tue Dec 12 11:00:24 EST 2006
Hi David,
In my experience, you can get the html template file to work using
strict xhtml 1.0, though it takes a little tweaking as you go. I've been
able to get it to work in both CGI mode and with php/mapscript.
I found it easier to start with new files than to retrofit some default
content.
Andy
Dave Potts wrote:
> Is the html template file going to be well form along the lines of xhtml ?
> David
