POSTGIS vs Shapefile mapserver optimization
Aaron Koning
aaronkoning at GMAIL.COM
Tue Dec 12 14:42:43 EST 2006
Also, OGR can be used to spatially index a shapefile (command: shptree),
which enables faster shapefile rendering in Mapserver.
http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?ShpTree
http://ogr.maptools.org/drv_shapefile.html
Aaron
On 12/12/06, Gregor Mosheh <gregor at hostgis.com> wrote:
> > Ask for the details you need to help me if you need some more ...
> Actually, it's usually the other way around. ;)
> > What is the better way to get mapserver generating map faster !
> > Is POSTGIS optimizing the way that mapserver build the map ?
> Typically, shapefiles are faster; or at least that's what I've
> consistently been told is true for the majority of cases.
> If your PostGIS performance is slow, make sure you have indexes! Nothing
> affects performance as much as indexes, and they're an easy thing to
> forget to do. Ensure that there's a GiST index on your geometry column, as
> well as on on your oid column. If the indexes are missing, generate them
> as follows:
> create index tablename_the_geom on tablename (the_geom) using gist;
> create index tablename_oid on tablename (oid);
> analyze tablename;
| Aaron Koning
| Information Technologist
| Prince George, BC, Canada.
| Flexible Internet Spatial Template:
| http://fist-mapping.org
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20061212/187a0bf0/attachment.html
