AW: Mapserver+Windows+ArcSDE
ericallard
eric.allard at BOREAL-IS.COM
Tue Dec 12 16:10:12 EST 2006
Hi! Mike!
My name is Eric Allard,
I'm having some problem with the following setup:
OS: Windows:
Package: ms4w
Spatial DB: SDE on MsSQL
MS4W installation used:
http://maptools.org/ms4w/index.phtml?page=README_INSTALL.html#sde-9-1
Here's the error I get:
msDrawMap(): Image handling error. Failed to draw layer named 'MineArea'.
msSDELayerOpen(): SDE error. SE_connection_create(): Operation Failed. (-1)
Here's my LAYER:
LAYER
NAME "MineInfra"
TYPE POLYGON
STATUS ON
CONNECTION "localhost,port:5151,sde,sa,"
CONNECTIONTYPE SDE
DATA "sde.dbo.ERIC,shape,"
FILTER "where shape is not NULL"
CLASS
TEMPLATE void
NAME "Phase 1"
COLOR 150 185 255
OUTLINECOLOR 110 110 110
END
END # LAYER
I really appreciate your time on this issue!
I really need to nail this one!
Cheers,
-Eric
Mike Saunt wrote:
> Hi
> We've successfully connected through to SDE (with the help of Howard) and
> it
> proves to be pretty simple. I am very happy with taking MS4W, extracting
> our required installation files and then applying the relevant
> libmap.dll(from the sub directory) when on site and then changing the
> connection
> strings. I'm very happy with this method as we don't need to recompile
> (although we do for other reasons!)
> Regards
> Mike
> On 25/10/06, Pleyer, Walter <Walter.Pleyer at lfrz.at> wrote:
>> Hi Howard!
>> > you get these errors. Are you trying to just render a layer?
>> Yes, just simply rendering it is all we try to do.
>> The backend DB is a Oracle 9.2.0.4 .
>> > to build MapServer and all of its dependencies from scratch
>> > on your platform of choice (Windows in your case). The time
>> > and misery required to do that is at least an order of
>> > magnitude larger than peeling apart the .\bin and .\cgi-bin
>> > directories plus the SDE libmap.dll from the MS4W package.
>> I'm aware of that.
>> That's why I hoped that someone might have done that already.
>> But this is certainly the lesser problem and more a matter of
>> convinience.
>> Walter
View this message in context: http://www.nabble.com/Mapserver%2BWindows%2BArcSDE-tf2502108.html#a7841791
Sent from the Mapserver - User mailing list archive at Nabble.com.
