download loop msHTTPExecuteRequests() ?
Daniel Morissette dmorissette at MAPGEARS.COM
Thu Dec 14 10:06:59 EST 2006
You are probably running under IIS? That's the "DEBUG ON" messages that
are merged with standard output under IIS. Remove all instances of
"DEBUG ON" in your mapfile and you should be fine.
Daniel
robert fritz wrote:
> Dear List,
> I have a small application on top of php-mapscript. One project uses WMS layers. There are displayed in the map-window, but if I try to print the map, I get a strange error - message:
> scalefactor = 0.52007 scalefactor = 0.52007 HTTP: Starting to prepare HTTP requests. HTTP request: id=1, http://www.geoserver.nrw.de:80/GeoOgcWms1.3/servlet/GEPNRW?LAYERS=GEPNRW%3AGEP%2520Gesamt&REQUEST=GetMap&SERVICE=WMS&FORMAT=image%2Fpng&STYLES=&HEIGHT=2584&VERSION=1.1.0&SRS=EPSG:31492&WIDTH=1824&BBOX=2571639%2C5682644%2E791666667%2C2572708%2C5684159%2E208333333&TRANSPARENT=TRUE&EXCEPTIONS=application/vnd.ogc.se_inimage HTTP: Before download loop msHTTPWriteFct(id=1, 308 bytes) HTTP: After download loop msHTTPExecuteRequests() timing summary per layer (connect_time + time_to_first_packet + download_time = total_time in seconds) Layer 1: 0.030 + 0.019 + 0.030 = 0.079s msDrawRasterLayerLow(WMSGEP): entering.
> For printing, a new map is created to increase the quality and to create a pdf.
> The error-message appears, when the request for printing is made. I use the same php script to create a map for display in the browser and for printing - only the image-size and the scale differs. What does the error means?
> regards,
> Robert
> ______________________________________________________________________________
> "Ein Herz für Kinder" - Ihre Spende hilft! Aktion: www.deutschlandsegelt.de
> Unser Dankeschön: Ihr Name auf dem Segel der 1. deutschen America's Cup-Yacht!
Daniel Morissette
http://www.mapgears.com/
