c# mapscript group of layers
Tamas Szekeres
szekerest at GMAIL.COM
Sat Dec 16 12:45:29 EST 2006
Fanda,
How would you use this functionality?
Currently you can use the group (read/write) property of the layer to
determine whether a layer belongs to a group.
However the more sophisticated functions like GetLayersIndexByGroup
and GetAllGroupNames are not exposed to the SWIG API at the moment.
Best Regards,
Tamas Szekeres
2006/12/15, Fanda <zerosgm at gmail.com>:
> Is it possible to use groups of layers (item GROUP in LAYER section of map
> file) when using C# mapscript? Because when I tried to do so in the same way
> as with single layer (layer = new layerObj(name); ) then it looks like it
> didn't find it and returns a null value.
> TIA, Fanda
> View this message in context: http://www.nabble.com/c--mapscript-group-of-layers-tf2826294.html#a7889217
> Sent from the Mapserver - User mailing list archive at Nabble.com.
