svg output blank
Yewondwossen Assefa
assefa at DMSOLUTIONS.CA
Sun Dec 17 11:38:02 EST 2006
Hi There,
Is it possible that the layer in question (parcels) would not be drawn
either because the status is off or min/max scale settings ? The svg
output seems to indicate that. Quick tests you ca do is set the status
on and remove the min/max scales settings and use shp2img (something
like shp2img -m yourmap.map -o ttt.svgz) and see the results.
Later,
Michael Leong wrote:
> Hi,
> I can get correct png output, but if I set the outputformat to svg, I
> get an incomplete svg xml.
> I'm running 4.10.0
> MapServer version 4.10.0 OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP OUTPUT=SVG
> SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
> SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT SUPPORTS=THREADS SUPPORTS=GEOS
> INPUT=EPPL7 INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
> Here's what I'll get:
> <?xml version="1.0" encoding="UTF-8"?>
> <svg version="1.1" width="256" height="256"
> xmlns="http://www.w3.org/2000/svg"
> xmlns:xlink="http://www.w3.org/1999/xlink">
> <!-- START LAYER parcels -->
> </svg>
> Here's my mapfile:
> MAP
> NAME "MapFile"
> STATUS ON
> EXTENT -23612250.268332410 5516496.445967868 -23612097.565338667
> 5516649.148961612
> SIZE 512 512
> SYMBOLSET "./etc/gexSymbols.sym"
> FONTSET "./etc/fonts.txt"
> IMAGETYPE png24a
> IMAGECOLOR 254 247 230
> UNITS METERS
> DEBUG ON
> WEB
> IMAGEPATH "/var/www/html/ms_tmp/"
> IMAGEURL "/ms_tmp/"
> LOG "/var/www/html/ms_tmp/test_mapserver.log"
> END
> QUERYMAP
> STATUS ON
> SIZE 150 100
> COLOR 0 55 255
> STYLE NORMAL
> END
> PROJECTION
> "proj=merc"
> "units=m"
> "lat_ts=0"
> "lon_0=0"
> "k=1.000000"
> "x_0=0"
> "y_0=0"
> "a=6371000"
> "b=6371000"
> END
> LEGEND
> STATUS OFF
> OUTLINECOLOR 51 51 255
> IMAGECOLOR 255 255 255
> TRANSPARENT ON
> INTERLACE ON
> POSITION LL
> KEYSIZE 30 15
> KEYSPACING 10 10
> POSTLABELCACHE TRUE
> LABEL
> TYPE TRUETYPE
> FONT "LucidaTypewriterBoldOblique"
> SIZE 11
> BUFFER 0
> MINDISTANCE -1
> MINFEATURESIZE -1
> COLOR 175 175 175
> OUTLINECOLOR 25 25 25
> ANTIALIAS TRUE
> END
> END
> SCALEBAR
> STATUS OFF
> SIZE 400 10
> COLOR 122 100 255
> OUTLINECOLOR 222 222 0
> BACKGROUNDCOLOR 155 155 155
> TRANSPARENT ON
> UNITS FEET
> INTERVALS 4
> STYLE 0
> POSITION LL
> INTERLACE ON
> LABEL
> TYPE BITMAP
> FONT "LucidaSansRegular"
> SIZE MEDIUM
> POSITION AUTO
> COLOR 0 0 0
> END
> END
> OUTPUTFORMAT
> NAME "jpeg"
> MIMETYPE "image/jpeg"
> DRIVER "GD/JPEG"
> EXTENSION "jpg"
> IMAGEMODE RGB
> TRANSPARENT FALSE
> FORMATOPTION "QUALITY=90"
> END
> OUTPUTFORMAT
> NAME "png8"
> MIMETYPE "image/png"
> DRIVER "GD/PNG"
> EXTENSION "png"
> IMAGEMODE PC256
> TRANSPARENT TRUE
> END
> OUTPUTFORMAT
> NAME "png24a"
> DRIVER "GD/PNG"
> EXTENSION "png"
> IMAGEMODE RGBA
> TRANSPARENT TRUE
> END
> OUTPUTFORMAT
> NAME svg
> MIMETYPE "image/svg+xml"
> DRIVER svg
> FORMATOPTION "COMPRESSED_OUTPUT=FALSE"
> FORMATOPTION "FULL_RESOLUTION=TRUE"
> END
> LAYER
> PROJECTION
> "init=epsg:4326"
> END
> NAME "parcels"
> GROUP "parcels"
> STATUS OFF
> DATA "the_geom from parcels USING SRID=4326"
> TYPE LINE
> CONNECTIONTYPE POSTGIS
> CONNECTION "host=xyz port=123 user=user1 password=password1 dbname=db1"
> SIZEUNITS PIXELS
> LABELCACHE ON
> MAXSCALE 11001
> DEBUG TRUE
> CLASSITEM "s_pin"
> CLASS
> EXPRESSION //
> NAME "parcels"
> DEBUG ON
> STYLE
> SYMBOL "lines2"
> SIZE 2
> ANTIALIAS TRUE
> OUTLINECOLOR 255 255 0
> COLOR -1 -1 -1
> END
> END
> END
> END
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax: (613) 565-0925
