mapserver raster documentation
Ed McNierney ed at TOPOZONE.COM
Mon Dec 18 09:43:27 EST 2006
John -
The only other thing I¹d add to the mix is the suggestion that you try to
get this data on an external FireWire drive rather than on 2,500 DVDs.
We¹ve been selling large collections of US GeoTIFF imagery for years and we
almost never use DVDs for distribution ­ and certainly never more than 5 or
6 for a single order.  If you¹ve got around a terabyte of imagery you can
fit that on a single external drive (or come close to it).  That is a huge
convenience for you in loading the data, and when you¹re processing it you
can simply connect that drive as your input source and pull data directly
from it so you don¹t need to worry about running out of source data in a
batch job.  If you¹re acquiring this data from a vendor I would expect
they¹d prefer to deliver it that way, too.
You will also see better processing performance if your input and output
files (at each step) are on different disks so you¹re not simultaneously
reading from and writing to the same device.
     - Ed
Ed McNierney
President and Chief Mapmaker
Maps a la carte, Inc. / TopoZone.com
73 Princeton Street, Suite 305
North Chelmsford, MA  01863
Phone: (978) 251-4242
Fax: (978) 251-1396
ed at topozone.com
Reply-To: John Mitchell <mitchelljj98 at GMAIL.COM>
Date: Sun, 17 Dec 2006 09:53:44 -0500
To: <MAPSERVER-USERS at LISTS.UMN.EDU>
Subject: Re: [UMN_MAPSERVER-USERS] mapserver raster documentation
Frank,
The reason why I had:
OUTPUTFORMAT
   NAME png
   DRIVER "GD/PNG"
   MIMETYPE "image/png"
   IMAGEMODE RGB
   EXTENSION "png"
  END
listed was that for ECW files you had DRIVER "GDAL/JP2ECW" and I am
wondering if you need a special driver for Imagine format.
In the next few months I may have to ingest 2500 DVD's of GeoTiff imagery
data covering portions of the United States with each DVD contain 1 image of
about 1.1 GB in size.  In looking over the MapServer Raster documentation I
could do the following:
a.) Keep as GeoTiff format
     1.) Convert all the images from whatever their current projection is to
WGS84 using GDALWARP.
     2.) Build internal tiling to each GeoTiff image utilizing:
gdal_translate -co TILED=YES orig.tif tiled.tif
     3.) Build internal overviews using: gdaladdo -r average *.tif 2 4 8 16
32 64 128
     4.) Build external tiling using: gdal_index doq_index.shp doq/*.tif
This will link all the geotiff's in the doq folder to the doq_index.shp,
which then is referenced in tileindex within layer instead of DATA.
     5.) ?When using tile indexes to manage many raster files as a single
file, it is especially important to have a overview layer that kicks in at
high (should'nt this say low instead?) scales to avoid having to open a
large number of raster files.  Building external overviews use either
gdal_merge or gdalwarp (eg gdalwarp -rc -tr 250 250 doq/*.tif overview.tif)
The 250 within the gdalwarp statement means a output resolution of 250
meters?
b.) Convert from GeoTiff to Imagine format
     2.) Mosaic all the GeoTiff's and convert to Imagine format using:
gdalwarp -of HFA doq/*.tif tiled.img
     3.) Build internal overviews using: gdaladdo -r average tiled.img 2 4 8
16 32 64 128
Which method would you recommend a or b as far as performance?
Thanks,
John J. Mitchell
On 12/16/06, Frank Warmerdam <warmerdam at pobox.com> wrote:
> John Mitchell wrote:
>> > Hi,
>> > I have been reading over the mapserver raster documentation and I have a
>> > few questions:
>> > 1.) It mentioned a 4 gb limit for GeoTiff files.  Is this for GeoTiff
>> > files or that GeoTiff's can only be tiled up to 4 gb.  Is this 4 gb
>> > limit an issue with mapserver or GeoTiff.
> John,
> The 4GB limit is inherent in TIFF, and it isn't specific to mapserver
> in any way.  Note that you can setup a tile index with my TIFF files
> smaller than 4GB.  There is no meaningful limit on the amount of data
> that can be in a tileindex.
>> > 2.) Assuming the 4 gb GeoTiff limit then the GeoTiff would need to be
>> > converted to Erdas Imagine (HFA) format.  The Documentation said that
>> > the Imagine format is already Tiled.  Correct?
> Imagine format is inherently tiled, normally with 64x64 blocks.
>> > 3.) Is the format the same to access an Imagine file as it is to access
>> > a GeoTiff?  I have a sample .map segment that I use to access a GeoTiff:
> Yes, Imagine files are accessed the same way in mapserver as GeoTIFF files
> are.
>> >  OUTPUTFORMAT
>> >   NAME png
>> >   DRIVER "GD/PNG"
>> >   IMAGEMODE RGB
>> >   EXTENSION "png"
>> >  END
> I'm not sure why this OUTPUTFORMAT declaration is in your email.  It didn't
> seem to relate to the text of question 3.  But I will say that output formats
> is to some degree a distinct issue from input raster formats.
> Best regards,
> I set the clouds in motion - turn up   | Frank Warmerdam, warmerdam at pobox.com
> <mailto:warmerdam at pobox.com>
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush    | President OSGeo, http://osgeo.org
> <http://osgeo.org>
John J. Mitchell
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20061218/80f4f486/attachment.html
