Changing Output Projection
Bill Thoen
bthoen at GISNET.COM
Thu Dec 21 16:48:46 EST 2006
Well, that was easy! Thanks!
Frank Warmerdam wrote:
> Bill Thoen wrote:
>> I'm pulling a polygon layer from Postgis and displaying it in
>> MapServer, but I can't seem to change the output projection. The
>> polygon layer's native coordinate system is WGS84, and when I check
>> MapServer with th e-v switch it says it supports PROJ. The
>> unprojected map displays fine if I use decimal degrees, but it seems
>> to be ignoring my PROJECTION settings the map file. Can someone tell
>> me what's wrong? Here's the map file:
> Bill,
> I believe the problem is that you are declaring the layer data to be
> UTM too.
> The PROJECTION definition on the layer should be the source coordinate
> system
> while the PROJECTION definition on the map should be the desired output
> projection. So change the layer to
> PROJECTION
> "+proj=latlong +datum=WGS84"
> END
