avoid label collision in scalebar
Bart van den Eijnden (OSGIS) bartvde at OSGIS.NL
Wed Dec 27 13:33:30 EST 2006
Another option could be to just leave out some of the labels, for
instance if I have 5 intervals, just display 3 labels instead of 6. IMHO
that would be the best option.
Best regards,
Bart
Bart van den Eijnden (OSGIS) schreef:
> For my use case only the third option would solve it. I have overlaps
> when displaying 0.4 and 0.6 km for instance, so changing to meters
> will make it worse, and the precision if as low as it goes.
> But then again, I can just reduce the number of intervals for now I
> guess.
> Thanks for the idea Steve, though some enhancement in this area would
> be nice ofcourse :-)
> Best regards,
> Bart
> Steve Lime schreef:
>> Bart: There is no mechanism in place at the moment to avoid this. There
>> would be a couple of strategies
>> to employ in the C code, which one would depend on the nature of the
>> overlap (e.g. too many places vs.
>> to many intervals):
>>   - allow definition of a format string for labels
>>   - define a unit of measure hierarchy (e.g. km -> m -> cm)
>>   - automatically reduce the number of intervals if overlap is
>> detected
>> Just some ideas...
>> Steve
>>>>> "Eijnden, Bart van den (AGI)" <b.vdeijnden at AGI.RWS.MINVENW.NL>
>> 12/27/2006 9:47:12 AM >>>
>> Hi list,
>> is there a way to avoid label collision in the scalebar?
>> Currently, when I zoom in very far, the labels overlap which makes the
>> scalebar unreadable.
>> Is it possible to avoid this, if so does anybody have a set of SCALEBAR
>> settings to share?
>> Thanks in advance.
>> Best regards,
>> Bart
>> Disclaimer
>> Aan dit bericht kunnen geen rechten worden ontleend. Dit bericht is
>> uitsluitend bestemd voor de geadresseerde. Als u dit bericht per abuis
>> hebt ontvangen, wordt u verzocht het te vernietigen en de afzender te
>> informeren. Wij adviseren u om bij twijfel over de juistheid of de
>> volledigheid van de mail contact met afzender op te nemen.
>> This message shall not constitute any rights or obligations.
>> This message is intended solely for the addressee.
>> If you have received this message in error, please delete it and
>> notify the sender immediately. When in doubt whether this message
>> is correct or complete, please contact the sender.
OSGIS, Open Source GIS
bartvde at osgis.nl
http://www.osgis.nl
