Reading the Same Selection from PostGIS Twice?
Steve Lime
Steve.Lime at DNR.STATE.MN.US
Wed Dec 27 16:33:43 EST 2006
If you have separate layers then you'll hit the server twice, yes. Why
do
you need them in separate layers? You certainly can achieve the visual
effect
(outlined polygons) within a single layer definition.
Steve
>>> Bill Thoen <bthoen at GISNET.COM> 12/27/2006 2:43:57 PM >>>
I've got a situation where I'm pulling the same selection of US county
polygons from PostGIS in two LAYERs because I want filled polygons in a
separate layer than the polygon outlines. I can make this work by
defining the same DATA selection statement for each LAYER, but doesn't
this hit the PostGIS server twice? Is there a way to select the
geometry
from the database once and then split the selection into separate
POLYGON type and LINE type layers within the MAP object?
