How to Construct Railroad Style lines?
Bill Thoen
bthoen at GISNET.COM
Fri Dec 29 15:17:09 EST 2006
It seems that line styles for railroads (i.e. lines that look like
---|--|--|--|--) are pretty hard to find in the documentation. I did
find one googlit on the subject from 2003
(http://mapserver.gis.umn.edu/data2/wilma/mapserver-users/0302/msg00716.html)
but I can't seem to make it work. The following map file excerpt built
from that suggestion just seems to produce a simple red line. I don't
see how this makes the "tie" lie crossways to the track line. Does
anyone know what I did wrong? Is there a more modern solution?
MAP
SYMBOL
NAME 'line'
TYPE ELLIPSE
FILLED TRUE
POINTS 1 1 END
END
SYMBOL
NAME 'tie'
TYPE ELLIPSE
FILLED TRUE
POINTS 1 1 END
STYLE 1 3 END
END
LAYER
NAME railroads
GROUP transportation
TYPE LINE
STATUS ON
CONNECTIONTYPE OGR
CONNECTION "railroads.TAB"
LABELITEM "Name"
CLASS
NAME "Railroads"
COLOR 255 100 100
SYMBOL 'line'
SIZE 1
OVERLAYSYMBOL 'tie'
OVERLAYSIZE 3
END
PROJECTION
"init=epsg:4326"
END
END
END
TIA,
- Bill Thoen
