SLD troubles - desperate!
edfialk
wef1 at CEC.WUSTL.EDU
Fri Dec 29 18:12:07 EST 2006
I have been unable to get my WMS capable MapServer to recognize an sld passed
in through the url (SLD=http:...)
The sld is readable, I have tested it on an example from the SLD
documentation - i.e. written my own SLD and pointed to it from the example,
works perfectly.
I am totally out of ideas as to why I cannot get it to show up on my own
server.
I'll give as much information as i can, any help would be extremely
appreciated.
map file:
MAP
NAME "All"
STATUS on
SIZE 800 600
EXTENT -2200000 -712631 3072800 3840000
UNITS METERS
SHAPEPATH "/var/www/html/mapserver/mapdata/"
IMAGECOLOR 220 220 220
FONTSET "/var/www/html/mapserver/mapdata/"
WEB
IMAGEPATH "/var/www/html/tmp/"
IMAGEURL "/tmp/"
METADATA
"wms_title" "All"
"wms_onlineresource" "http://niceguy.wustl.edu/cgi-bin/mapserv.exe?"
"wms_srs" "epsg:4326"
END
END
PROJECTION
"init=epsg:4326"
END
LAYER
NAME NAmer_bdr
METADATA
"wms_title" "NAmer_bdr"
END
TYPE LINE
STATUS on
DATA bound_p
PROJECTION
"init=epsg:4326"
END
CLASS
STYLE
OUTLINECOLOR 0 0 0
END
END
END
SLD File:
<StyledLayerDescriptor version="1.0.0">
<NamedLayer>
<Name>NAmer_bdr</Name>
<UserStyle>
<Title>NAmer_bdr</Title>
<FeatureTypeStyle>
<Rule>
<LineSymbolizer>
<Geometry>
<PropertyName>center-line</PropertyName>
</Geometry>
<Stroke>
<CssParameter name="stroke">#00FF00</CssParameter>
</Stroke>
</LineSymbolizer>
</Rule>
</FeatureTypeStyle>
</UserStyle>
</NamedLayer>
</StyledLayerDescriptor>
and just in case:
MapServer version 4.10.0 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
OUTPUT=PDF OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER
INPUT=EPPL7 INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
Please, please any help.
Thanks!
-Ed
View this message in context: http://www.nabble.com/SLD-troubles---desperate%21-tf2896949.html#a8093640
Sent from the Mapserver - User mailing list archive at Nabble.com.
