Java Mapscript no lib found
Oliver Lichte
lichte at ICBM.DE
Thu Feb 2 04:21:28 EST 2006
Hi group,
I've got a problem using Java mapscript V4.6.2 on a 64bit machine (AMD
Opteron) and SuSE 10.0, since the JNI libmapscript.so is not found although
it's there. On a 32Bit machine everything works fine with the same OS, Java
and Mapserver set-ups, so the problem might concern the architecture. Has
anyone solved a similiar problem before? Who can help me?
My environment:
make test in 'mapscript/java' shows:
> make test
javac -classpath ./:examples/:./mapscript.jar -d examples/ examples/*.java
java -classpath ./:examples/:./mapscript.jar -Djava.library.path=.
DumpShp ../../tests/point.shp
java.lang.UnsatisfiedLinkError: /home/olichte/src/mapserver-4.6.2/mapscript/java/libmapscript.so: /home/olichte/src/mapserver-4.6.2/mapscript/java/libmapscript.so:
cannot open shared object file: No such file or directory
make: *** [test] Fehler 255
The lib is present at the requested path in directory and permissions are o.k:
> ls -l /home/olichte/src/mapserver-4.6.2/mapscript/java/libmapscript.so
-rwxr-xr-x 1 olichte impulse 1067739 2006-02-02
09:55 /home/olichte/src/mapserver-4.6.2/mapscript/java/libmapscript.so*
and all shared-libs are resolved, too:
> ldd libmapscript.so
libgd.so.2 => /usr/lib64/libgd.so.2 (0x00002aaaaacb5000)
libjpeg.so.62 => /usr/lib64/libjpeg.so.62 (0x00002aaaaae09000)
libfreetype.so.6 => /usr/lib64/libfreetype.so.6 (0x00002aaaaaf2a000)
libpng.so.3 => /usr/lib64/libpng.so.3 (0x00002aaaab0a5000)
libz.so.1 => /lib64/libz.so.1 (0x00002aaaab1df000)
libtiff.so.3 => /usr/lib64/libtiff.so.3 (0x00002aaaab2f4000)
libm.so.6 => /lib64/tls/libm.so.6 (0x00002aaaab44c000)
libstdc++.so.6 => /usr/lib64/libstdc++.so.6 (0x00002aaaab5a4000)
libc.so.6 => /lib64/tls/libc.so.6 (0x00002aaaab7a0000)
libXpm.so.4 => /usr/X11R6/lib64/libXpm.so.4 (0x00002aaaab9cb000)
libX11.so.6 => /usr/X11R6/lib64/libX11.so.6 (0x00002aaaabae2000)
libfontconfig.so.1 => /usr/lib64/libfontconfig.so.1
(0x00002aaaabcf1000)
libpng12.so.0 => /usr/lib64/libpng12.so.0 (0x00002aaaabe30000)
libgcc_s.so.1 => /lib64/libgcc_s.so.1 (0x00002aaaabf6a000)
/lib64/ld-linux-x86-64.so.2 (0x0000555555554000)
libXext.so.6 => /usr/X11R6/lib64/libXext.so.6 (0x00002aaaac077000)
libdl.so.2 => /lib64/libdl.so.2 (0x00002aaaac188000)
libexpat.so.0 => /usr/lib64/libexpat.so.0 (0x00002aaaac28c000)
My architecture is:
> uname -a
Linux labrador 2.6.13-15-smp #1 SMP Tue Sep 13 14:56:15 UTC 2005 x86_64 x86_64
x86_64 GNU/Linux
> java -version
java version "1.4.2_06"
Java(TM) 2 Runtime Environment, Standard Edition (build 1.4.2_06-b03)
Java HotSpot(TM) Client VM (build 1.4.2_06-b03, mixed mode)
Thank you and cheers,
Oliver
Junior Research Group IMPULSE
ICBM * Carl-v.-Ossietzky University of Oldenburg
PO-Box 2503 * 26111 Oldenburg - Germany - http://www.icbm.de/impulse
room: W15-2-239 * fon:+49-441-798-3622 * fax:+49-441-798-3404
