Java Mapscript no lib found
Oliver Lichte lichte at ICBM.DE
Thu Feb 2 07:09:01 EST 2006
Sorry. Here a copy for the group again:
Yes, I am using the 64bit Version of SuSE 10.0 Linux-distr and I also
recompiled mapserver several times with different configurations. There is no
problem with tools like shp2img, thus the libmap.a seems to be good.
> ldd -r libmapscript.so
        libgd.so.2 => /usr/lib64/libgd.so.2 (0x00002aaaaacb5000)
        libjpeg.so.62 => /usr/lib64/libjpeg.so.62 (0x00002aaaaae09000)
        libfreetype.so.6 => /usr/lib64/libfreetype.so.6 (0x00002aaaaaf2a000)
        libpng.so.3 => /usr/lib64/libpng.so.3 (0x00002aaaab0a5000)
        libz.so.1 => /lib64/libz.so.1 (0x00002aaaab1df000)
        libtiff.so.3 => /usr/lib64/libtiff.so.3 (0x00002aaaab2f4000)
        libm.so.6 => /lib64/tls/libm.so.6 (0x00002aaaab44c000)
        libstdc++.so.6 => /usr/lib64/libstdc++.so.6 (0x00002aaaab5a4000)
        libc.so.6 => /lib64/tls/libc.so.6 (0x00002aaaab7a0000)
        libXpm.so.4 => /usr/X11R6/lib64/libXpm.so.4 (0x00002aaaab9cb000)
        libX11.so.6 => /usr/X11R6/lib64/libX11.so.6 (0x00002aaaabae2000)
        libfontconfig.so.1 => /usr/lib64/libfontconfig.so.1
(0x00002aaaabcf1000)
        libpng12.so.0 => /usr/lib64/libpng12.so.0 (0x00002aaaabe30000)
        libgcc_s.so.1 => /lib64/libgcc_s.so.1 (0x00002aaaabf6a000)
        /lib64/ld-linux-x86-64.so.2 (0x0000555555554000)
        libXext.so.6 => /usr/X11R6/lib64/libXext.so.6 (0x00002aaaac077000)
        libdl.so.2 => /lib64/libdl.so.2 (0x00002aaaac188000)
        libexpat.so.0 => /usr/lib64/libexpat.so.0 (0x00002aaaac28c000)
> ldd  libmapscript.so
Seems to be no difference.
Oliver
Am Donnerstag 02 Februar 2006 11:09 schrieben Sie:
> Are you using 64bit version of the OS? If  yes did you recompile
> mapserver or just copied it over?
> Try to give the -r option to ldd.
> Umberto
Junior Research Group IMPULSE
ICBM * Carl-v.-Ossietzky University of Oldenburg
PO-Box 2503 * 26111 Oldenburg - Germany - http://www.icbm.de/impulse
room: W15-2-239 * fon:+49-441-798-3622 * fax:+49-441-798-3404
