Java Mapscript no lib found
Oliver Lichte
lichte at ICBM.DE
Thu Feb 2 07:15:01 EST 2006
That's a good hint. /usr/bin/java is not linked against 64bit libraries, so I
will try to install a 64-bit jvm and start it again.
Thank you,
Oliver
Am Donnerstag 02 Februar 2006 11:48 schrieb Umberto Nicoletti:
> Please always add the list to your replies!
> Are you using a 64 bit JVM?
> Regards,
> Umberto
Software-Developer * Junior Research Group IMPULSE
ICBM * Carl-v.-Ossietzky University of Oldenburg
PO-Box 2503 * 26111 Oldenburg - Germany - http://www.icbm.de/impulse
room: W15-2-239 * fon:+49-441-798-3622 * fax:+49-441-798-3404
