Can you help me with this map file?
Jeremy Stocks
stocksll33 at YAHOO.CO.UK
Thu Feb 2 13:03:19 EST 2006
Hi there to the list.
I have succeeded in downloading SRTM and Landsat from the GLCF, VMAP
Level 0 from the web and processing them in GRASS. I have done the same
with Geonet names from NIMA with the help of a pythin script an internet
buddy wrote for me.
I am now trying to incorporate the label names into my Mapserver
application. Can anyone help? I have a problem with the below MAP file.
When I run Mapserver on my PC (standard Windows download version) I
receive this message:
loadLayer(): Unknown identifier. Parsing error near (LAYER):(line 88)
Is the MAP script wrong here? I am a newbie to MAPserver.
For whatever help anyone gives I will be very grateful.
Regards,
Jeremy Stocks.
Here is the script. The problem area is the bold italic section.......
# The annotated map file (sort of)
# Created by Pericles S. Nacionales for the MapServer tutorial
# 20050408
# MapServer map file uses the pound sign (#) to denote the start of a line
# comment--each line that needs to be commented has to be prepended with
a "#".
# Map files begin with MAP keyword to signify the start of the map object.
# Well, the entire map file is THE map object. Enclosed between MAP and END
# at the very bottom of this map file, are keyword/value pairs and other
# objects.
MAP
IMAGETYPE PNG
EXTENT 658768.76306283 5255756.95394429 742048.26144778
5330768.35385309
SIZE 700 500
SHAPEPATH "\ms4w\Apache\htdocs\bayern"
IMAGECOLOR 255 255 255
FONTSET "\ms4w\Apache\htdocs\bayern\fonts.list"
WEB
TEMPLATE "c:\ms4w\Apache\htdocs\bayern\bayern.html"
IMAGEPATH "/ms4w/tmp/ms_tmp/"
IMAGEURL "/ms_tmp/"
END
# Layer objects are defined beneath the map object. You need at least one
# layer defined in your map file before you can display a map... You can
# define as many layers as you'd like although a limit is typically
hard-coded
# in map.h in the MapServer source. The default limit is set at 100.
You'd
# have to have a very specialized application to need more than 100
layers in
# your application.
# Start of LAYER DEFINITIONS ---------------------------------------------
LAYER # Brovey raster layer begins here
NAME "brov_rgb_composite"
DATA "brov_rgb_composite.tif"
STATUS OFF
TYPE RASTER
END # Brovey raster layer ends here
LAYER # SRTM raster layer begins here
NAME "srtm_u03_p193r027_2ndattemptimport"
DATA "srtm_u03_p193r027_2ndattemptimport.tif"
STATUS OFF
TYPE RASTER
END # SRTM raster layer ends here
HERE begin the problems.......! from HERE.....
LAYER # Geonet names
NAME popl_anno
STATUS DEFAULT
DATA "GNS_subset.shp"
TYPE POINT
CLASSITEM "fc"
LABELITEM "fnamend"
CLASS
NAME "Populated places"
STYLE
COLOR 232 20 20
END
LABEL
COLOR 132 31 31
SHADOWCOLOR 218 218 218
SHADOWSIZE 2 2
TYPE TRUETYPE
FONT arial
SIZE 12
ANTIALIAS TRUE
POSITION CL
PARTIALS FALSE
MINDISTANCE 300
BUFFER 4
END # end of label
END # Label layer ends here
......................................TO HERE!
LAYER # Lakes
NAME bavaria_lakes
DATA hydro_inwatera_lakes
STATUS ON
TYPE POLYGON
# The class object is defined within the layer object. You can define as
# many classes as you need (well, there are limits as with layers, but
it's
# senseless to define more than ten on a "normal" layer. There are
# situations, however, where you might have to do it.)
CLASS
NAME "Bavaria Lakes"
# There are styles in a class, just like there are classes in a layer,
# just like there are layers in a map. You can define multiple
styles in
# a class just as you can define multiple classes in a layer and
multiple
# layers in a map.
STYLE
COLOR 20 20 232
OUTLINECOLOR 32 32 32
END
END
END # Bavaria lakes polygon layer ends here
LAYER
NAME bavaria_rivers
DATA hydro_watrcrsl_river
STATUS ON
TYPE LINE
CLASS
NAME "Bavaria Rivers"
STYLE
COLOR 20 20 232
END
END
END # States line layer ends here
# End of LAYER DEFINITIONS -------------------------------
END # All map files must come to an end just as all other things must
come to...
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060202/68414762/attachment.html
