Can you help me with this map file?
Jeff McKenna
jmckenna at DMSOLUTIONS.CA
Thu Feb 2 13:24:10 EST 2006
are you missing an END for the "Geonet names" layer?
jeff
Jeremy Stocks wrote:
> Hi there to the list.
> I have succeeded in downloading SRTM and Landsat from the GLCF, VMAP
> Level 0 from the web and processing them in GRASS. I have done the same
> with Geonet names from NIMA with the help of a pythin script an internet
> buddy wrote for me.
> I am now trying to incorporate the label names into my Mapserver
> application. Can anyone help? I have a problem with the below MAP file.
> When I run Mapserver on my PC (standard Windows download version) I
> receive this message:
> loadLayer(): Unknown identifier. Parsing error near (LAYER):(line 88)
> Is the MAP script wrong here? I am a newbie to MAPserver.
> For whatever help anyone gives I will be very grateful.
> Regards,
> Jeremy Stocks.
> Here is the script. The problem area is the bold italic section.......
> # The annotated map file (sort of)
> # Created by Pericles S. Nacionales for the MapServer tutorial
> # 20050408
> # MapServer map file uses the pound sign (#) to denote the start of a line
> # comment--each line that needs to be commented has to be prepended with
> a "#".
> # Map files begin with MAP keyword to signify the start of the map object.
> # Well, the entire map file is THE map object. Enclosed between MAP and END
> # at the very bottom of this map file, are keyword/value pairs and other
> # objects.
> MAP
> IMAGETYPE PNG
> EXTENT 658768.76306283 5255756.95394429 742048.26144778
> 5330768.35385309
> SIZE 700 500
> SHAPEPATH "\ms4w\Apache\htdocs\bayern"
> IMAGECOLOR 255 255 255
> FONTSET "\ms4w\Apache\htdocs\bayern\fonts.list"
> WEB
> TEMPLATE "c:\ms4w\Apache\htdocs\bayern\bayern.html"
> IMAGEPATH "/ms4w/tmp/ms_tmp/"
> IMAGEURL "/ms_tmp/"
> END
> # Layer objects are defined beneath the map object. You need at least one
> # layer defined in your map file before you can display a map... You can
> # define as many layers as you'd like although a limit is typically
> hard-coded
> # in map.h in the MapServer source. The default limit is set at 100.
> You'd
> # have to have a very specialized application to need more than 100
> layers in
> # your application.
> # Start of LAYER DEFINITIONS ---------------------------------------------
> LAYER # Brovey raster layer begins here
> NAME "brov_rgb_composite"
> DATA "brov_rgb_composite.tif"
> STATUS OFF
> TYPE RASTER
> END # Brovey raster layer ends here
> LAYER # SRTM raster layer begins here
> NAME "srtm_u03_p193r027_2ndattemptimport"
> DATA "srtm_u03_p193r027_2ndattemptimport.tif"
> STATUS OFF
> TYPE RASTER
> END # SRTM raster layer ends here
> HERE begin the problems.......! from HERE.....
> */LAYER # Geonet names
> NAME popl_anno
> STATUS DEFAULT
> DATA "GNS_subset.shp"
> TYPE POINT
> CLASSITEM "fc"
> LABELITEM "fnamend"
> CLASS
> NAME "Populated places"
> STYLE
> COLOR 232 20 20
> END
> LABEL
> COLOR 132 31 31
> SHADOWCOLOR 218 218 218
> SHADOWSIZE 2 2
> TYPE TRUETYPE
> FONT arial
> SIZE 12
> ANTIALIAS TRUE
> POSITION CL
> PARTIALS FALSE
> MINDISTANCE 300
> BUFFER 4
> END # end of label
> END # Label layer ends here/*
> ......................................TO HERE!
> LAYER # Lakes
> NAME bavaria_lakes
> DATA hydro_inwatera_lakes
> STATUS ON
> TYPE POLYGON
> # The class object is defined within the layer object. You can define as
> # many classes as you need (well, there are limits as with layers, but
> it's
> # senseless to define more than ten on a "normal" layer. There are
> # situations, however, where you might have to do it.)
> CLASS
> NAME "Bavaria Lakes"
> # There are styles in a class, just like there are classes in a layer,
> # just like there are layers in a map. You can define multiple
> styles in
> # a class just as you can define multiple classes in a layer and
> multiple
> # layers in a map.
> STYLE
> COLOR 20 20 232
> OUTLINECOLOR 32 32 32
> END
> END
> END # Bavaria lakes polygon layer ends here
> LAYER
> NAME bavaria_rivers
> DATA hydro_watrcrsl_river
> STATUS ON
> TYPE LINE
> CLASS
> NAME "Bavaria Rivers"
> STYLE
> COLOR 20 20 232
> END
> END
> END # States line layer ends here
> # End of LAYER DEFINITIONS -------------------------------
> END # All map files must come to an end just as all other things must
> come to...
Jeff McKenna
DM Solutions Group Inc.
http://www.dmsolutions.ca
