Mapserver not working in IIS, it DOES work command-line
Fernando Simon fsimon at UNIVALI.BR
Fri Feb 3 06:23:25 EST 2006
Hi Jelmer,
    In Oracle case, you need the Oracle environments (ORACLE_HOME,
ORACLE_BASE...) for the user that runs IIS. Another point is that you
need the Oracle Call Interfaces installed in machine. The last issue for
Oracle is that you need permission, for the user that run IIS, to access
the Oracle home installation, just a read mode can be.
    Best regards.
Fernando Simon
Mapserver and Oracle Spatial developer
G10 - Laboratorio de Computacao Aplicada - Brazil
http://www.univali.br/g10 - UNIVALI/CTTMAR
Jelmer Baas wrote:
> Hello everyone,
> After a lot of struggling with my maps, I finally have a test
> envirioment up and running. Now I'm moving the whole lot to the
> server, and this gives me a huge problem. When I try to generate a
> map, I am presented with:
> CGI Error
> The specified CGI application misbehaved by not returning a complete
> set of HTTP headers.
> The querystring is good, as is the mapfile (since it all works on my
> test machine).
> Info:
>  - Windows Server 2003, IIS6.0, fully updated
>  - Oracle Mapinfo package from http://hobu.stat.iastate.edu/mapserver/.
>  - Works in cmd (mapserv.exe "QUERY_STRING=mode=map&map=cocon.
> map&mapext=-70000+280000+400000+630000&mapsize=640+480&layers=netherlands"
> > test.jpg)
>  - I set rights for everyone to full control
>  - IIS CAN execute even unknown CGI files.
> I'm out of ideas here. Can anyone help? If I at least had a normal
> error message...
> Thanks in advance,
> Jelmer Baas
