Visualizing Point Data
Sean Gillies
sgillies at FRII.COM
Fri Feb 3 10:00:10 EST 2006
On Feb 3, 2006, at 12:06 AM, Bill Binko wrote:
> Hi everyone,
> I posted a fairly specific question to the GDAL-dev list (and more
> on IRC)
> the other day, asking for input on how to do Kernel Density mapping
> using
> an OGR data source and sending the raster back through GDAL to be
> displayed through Mapserver.
> I got some good responses, one of which was: are you sure that's
> what you
> want? Well, to be honest, I don't know. So I'm posting a more
> general
> question here, hoping that someone in this larger audience has
> solved the
> problem I'm facing.
> What I'm trying to do is visualize point data (stored in PostGIS,
> but that
> can change) so that users can determine where the points are
> concentrated,
> even while zoomed out. One caveat is that the points can be
> coincident
> (identical Lat/Long).
> For example, I'd use this with include recent real estate sales data -
> condos in the same building have the same shape, but both sales should
> count. Similarly, in a customer counting scenario, two customers
> with the
> same address (even only to the building level) will geocode to the
> same
> lat/long.
> When Mapserver serves up Point layers directly, the results can be
> quite
> disappointing (and misleading). In Mapserver, the last Point to be
> drawn
> on any spot will just hide the previous points, often hiding
> multiple data
> points.
> Similarly, when you zoom out on a point diagram, there are two
> options:
> either you set the symbol to have a max size (so that eventually, they
> become "less than clear"), or you keep the symbol size constant,
> eventually obliterating the background with huge blobs of overlapping
> points.
> When I tried to tackle this problem, I turned to a Real Estate
> Geography
> book I have (written by professor Thrall at my alma mater)
> http://www.amazon.com/gp/product/0195076362/sr=1-2/qid=1138949940/
> ref=sr_1_2/104-4827941-6490312?%5Fencoding=UTF8
> There, he is discussing Site Selection and Customer Spotting methods,
> and he discusses the Kernel Density method of generating a surface map
> showing where the customers live. The discussion is brief, but the
> GDAL
> folks pointed me to two tools (parts of R and GRASS respectively)
> that can
> take points and generate kernel surfaces. With some magic, contour
> maps,
> and other visualizations could be pushed through GDAL and into
> Mapserver.
> However, with further inspection, these methods all work on distance
> between customers, which causes a problem with coincident points.
> I am thinking that this problem must have been solved by someone
> out in
> this audience, so at this point, I'm very open to suggestions.
> I am very willing (and fairly able) to implement any custom
> software the
> solution my require. I have considered filters between GDAL and
> OGR, or
> stand alone processing that generates the needed data. I'm also very
> happy to feed it back to the community, if there's interest.
> (So, basically, I will trade working code for modeling/GIS/statistics
> knowledge if anyone's interested :)
> Thanks,
> Bill
Great synopsis, Bill. I'm looking forward to learning more about this.
One very simple-minded solution that MapServer *should* support is
drawing points with a low (say 10%) opacity, and simply painting them
over each other in an additive way. Currently, MapServer has
transparency only at the layer (not feature) level, and so this will
not work. I haven't had a real need for this yet, and so I haven't
been able to justify the cost of developing it.
cheers,
Sean
Sean Gillies
sgillies at frii dot com
http://zcologia.com/news
