shp2tile question
Stephen Woodbridge
woodbri at SWOODBRIDGE.COM
Fri Feb 3 13:42:45 EST 2006
Try setting DEBUG ON in every layer also.
You might have to upgrade to 4.6 but I don't recall.
-Steve
Eric Shuman wrote:
> Thanks for the info Steve!
> One problem though... I can't seem to get the debug to work. Nothing shows
> up in the log file I created. I am using version 4.4.1 Here is part of my
> MAP file. What am I missing?
> MAP
> NAME Proximity
> SIZE 2175 2175
> IMAGECOLOR 215 215 215
> SHAPEPATH "/GIS/data/deschutes/"
> EXTENT 4523731 708810 5081065 996372
> UNITS FEET
> DEBUG ON
> WEB
> IMAGEPATH "/GIS/fgs/tmp/ms_tmp/"
> IMAGEURL "/ms_tmp/"
> LOG "/GIS/logs/deschutes.log"
> END
> END
> -----Original Message-----
> From: Stephen Woodbridge [mailto:woodbri at swoodbridge.com]
> Sent: Thursday, February 02, 2006 5:11 PM
> To: Eric Shuman
> Cc: MAPSERVER-USERS at LISTS.UMN.EDU
> Subject: Re: [UMN_MAPSERVER-USERS] shp2tile question
> Eric,
> Here is how you should optimize mapserver:
> 1) every *.shp file should have a shptree index, (ie: a corresponding
> *.qix) if you haven't done this then don't think about anything else.
> This includes on all TILEINDEX shp files also.
> 2) If you have large numbers of objects that you need to do attribute
> queries on consider using postgis for just those layers.
> 3) I will let others comment on rasters and how to optimize them
> 4) Set "DEBUG ON" in the mapfile and create a LOG file, then do a
> typical mapdraw and look at how long each layer took to draw. Then tell
> us about that if it is not obvious how to fix that performance issue.
> 5) As a last resort, if you have REALLY HUGE shapefiles and they are
> drawing very slowly then consider using shp2tile, but talk about here on
> the list first.
> Let us know if this helps and what your problems are after you have
> tried this.
> -Steve W.
> http://imaptools.com/
> Eric Shuman wrote:
>>I also have a similar problem. Don, did you come up with a good solution?
>>I'm still new to mapserver and have not delved into the indexing
>>capabilities yet. Can someone enlighten me?
>>Here is my situation:
>>I have a map set up that displays cadastral data as well as other layers
>>such as streets and points of interest. From PHP I query the map by
>>attribute for a taxlot ID. The map layer itself is set to the full extent
>>of the data, and uses the parcel layer multiple times to show the query
>>results, as well as for other symbology purposes. When the lot is found
> the
>>map zooms to the extent of the results. The data extent covers an entire
>>county so the layers are fairly large, and the map takes awhile to draw.
>>The questions:
>>In all cases the final extent is pretty small, maybe 1 square mile max.
>>Should I be tiling my parcels layer with the shp2tile/ogrtindex combo and
>>then creating a shptree on the resulting index? OR Should I just create a
>>shptree on the parcels layer as well as all the other layers? Will the
>>shptree help when doing an attribute query, or do I need to find a
> different
>>solution for speeding up the attribute query? Any recomendations on how
> to
>>speed things up?
>>In addition I am serving up aerial photos. I have a 1Gig MrSid, but don't
>>really want to get into building mapserver from scratch to add the
>>functionality. So my though was to convert the SID to 2500 8Meg TIFF's,
> and
>>then run a gdaltindex on them, then maybe a shptree on the index. Is this
> a
>>sound plan? Other options? Does anyone have experience with the speed
>>differences of MrSid vs. TIFF?
>>Thanks for the help!
>>~Eric Shuman
>>On Mon, 18 Apr 2005 10:20:23 -0400, Don Deskins <dldeskins at GMAIL.COM>
> wrote:
>>>Steve,
>>>Thank you for your reply.
>>>I have experimented with different numbers and after reading a bit
>>>more, I have discovered that it make no difference (in my case) how I
>>>divide it up. As a matter of fact, my application performs SLOWER the
>>>more files that I have.
>>>What I am trying to do is to display an area with parcels of land. I
>>>have two identical layers... one to display all of the parcels and the
>>>other to only display the selected parcel. It is extremely slow when
>>>querying for by parcel id. Because of this, I need to put the second
>>>layer (at least) in a database so that the parcelid field can be
>>>indexed.
>>>Thanks,
>>>Don
>>>On 4/11/05, Stephen Woodbridge <woodbri at swoodbridge.com> wrote:
>>>>Don,
>>>>Like I said there is no magic number. If you are most showing all your
>>>>parcels most of the time then there is not value in having it tiled. One
>>>>of the MOST important performance issues is to make sure all your *.shp
>>>>files have a *.qix file.
>>>>Try a different set of tiling parameters and test it again.
>>>>Did you have *.qix on you original shapefile? If not go back to that and
>>>>add one (shptree file.shp) and see how it performs untiled.
>>>>-Steve
>>>>Don Deskins wrote:
>>>>>Bart and Steve,
>>>>>My shapefiles are showing up now... thanks!
>>>>>Now I have a time problem... It seems to take more time to generate
>>>>>the image than it did before. I am checking for errors now.
>>>>>Thanks again.
>>>>>Don
>>>>>On Apr 11, 2005 3:28 PM, Bart van den Eijnden <bartvde at xs4all.nl> wrote:
>>>>>>Hi Don,
>>>>>>check the dbf of your generated tileindex (the LOCATION field). I
> usually
>>>>>>use absolute paths in there. Are there absolute or relative paths to
> the
>>>>>>files in there?
>>>>>>Also use TYPE POLYGON. Are you zoomed in enough to have your layer
> showing
>>>>>>up, since you are using a MAXSCALE setting?
>>>>>>Best regards,
>>>>>>Bart
>>>>>>On Mon, 11 Apr 2005 15:24:45 -0400, Don Deskins <dldeskins at gmail.com>
>>>>>>wrote:
>>>>>>>Bart (and Steve),
>>>>>>>Thanks.
>>>>>>>I have my files created and tried to reference this index in my map
> file:
>>>>>>># parcels
>>>>>>>LAYER
>>>>>>> NAME 'tileindex'
>>>>>>> TYPE TILEINDEX
>>>>>>> DATA '/path/to/tileindex'
>>>>>>> MAXSCALE 40000
>>>>>>>END
>>>>>>>LAYER
>>>>>>> NAME 'SCAP_Cert2004_ParcelsUTM16M'
>>>>>>> STATUS ON
>>>>>>> TYPE POLYGON
>>>>>>> TILEINDEX '/path/to/tileindex'
>>>>>>> #TILEITEM 'LOCATION'
>>>>>>> MAXSCALE 40000
>>>>>>>END
>>>>>>>I get no error but my shapes are not showing up... do you see a
>>>>>>>problem with the above map?
>>>>>>>Don
>>>>>>>On Apr 11, 2005 2:58 PM, Bart van den Eijnden <bartvde at xs4all.nl>
> wrote:
>>>>>>>>Hi,
>>>>>>>>It is tile4ms, not tile2ms, probably a typo by Steve.
>>>>>>>>It is a Mapserver utility to make a tileindex. Alternatively, you can
>>>>>>>>also
>>>>>>>>use ogrtindex for vector layers and gdaltindex for raster layers.
>>>>>>>>Best regards,
>>>>>>>>Bart
>>>>>>Using Opera's revolutionary e-mail client: http://www.opera.com/m2/
>>>>>Don Deskins
>>>Don Deskins
