UNC path in mapfile
Clint Johnson cjohnson at REFRACTIONS.NET
Fri Feb 3 14:01:18 EST 2006
Suggestions:
1.  Try it out with the .sid file locally to check that your issue is in
fact with UNC/Networking, and not an issue of having errors in your map
file.
2.  (long shot) Try (note dollar sign):
DATA "\\192.168.51.15\d$\arcims\sid83\2003\Ortho_1-
1_1n_s_nd035_2003_1.sid"
3.  Consider architecture issues: If your mapserver deployment is
running on linux machine and trying to access via UNC on a windows 2003
server, then there it is likely to fail (depending on your Samba version
and linux kernel) as Win2003 server (by default) uses CIFS.  CIFS is
encrypted and older version of Samba will fail to connect access it.
Not entirely sure if the inverse is also true...
4.  Try mapping the UNC share locally, and using that local share (eg
Z:\<path>) in the mapfile.
5.  Reevaluate your UNC/windows file sharing permissions under windows/IIS.
http://support.microsoft.com/kb/271071/EN-US/
http://support.microsoft.com/kb/q257174/
Clint
Clint Johnson
Refractions Research Inc.
Cjohnson at refractions.net
krishna S wrote:
> Hello all, i was wondering how can we set a unc path in the mapfile. I have
> a sid file on a different computer, i set the proper permissions and gave
> the unc path but the image doesnt show up.
> This was the entry i made in mapfile
> LAYER
>     NAME "RASTER"
>     TYPE RASTER
>     DATA "\\192.168.51.15\d\arcims\sid83\2003\Ortho_1-
>     OFFSITE 0 0 0
>     STATUS DEFAULT
>   END
> Any suggestions please .....
> --kris
