tile4ms question
Ed McNierney
ed at TOPOZONE.COM
Fri Feb 3 14:53:56 EST 2006
Jerl -
Do you have a .shx and .dbf file for it, too? Can you look at a file in
the same or nearby directory that DOES work to see if you can detect any
difference?
- Ed
Ed McNierney
President and Chief Mapmaker
TopoZone.com / Maps a la carte, Inc.
73 Princeton Street, Suite 305
North Chelmsford, MA 01863
ed at topozone.com
(978) 251-4242
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
Behalf Of Jerl Simpson
Sent: Friday, February 03, 2006 2:37 PM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: Re: [UMN_MAPSERVER-USERS] tile4ms question
Just an update, I upgraded to mapserver 4.8.0 and tried using the
tile4ms provided, with the same result.
If anyone has any ideas I'd greatly appreciate any help you might be
able to give.
Thanks,
Jerl
On 2/3/06, Jerl Simpson <jerl.simpso at gmail.com> wrote:
I'm not sure if this should be posted here or not, if not please
point me to the right place.
I'm having trouble with tile4ms opening the files from at least
one of my Metafile.txt files.
The command I run is as follows:
tile4ms Metafile.txt tileindex
error is:
Aborted. Unable to open
SHP:/var/mapping/tiger_2005/PriRoad/tiles/PriRoad_0037.200_-105.400
I thought maybe my filename was too long, but I checked the
source, 255 is the max. So I'm OK there.
ogrinfo has this to say about the file:
Layer name: PriRoad_0037.200_-105.400
Geometry: Line String
Feature Count: 459
Extent: (-104.835908, 36.412144) - (-104.424129, 37.988177)
Layer SRS WKT:
GEOGCS["NAD83",
DATUM["North_American_Datum_1983",
SPHEROID["GRS 1980",6378137,298.257222101 ]],
PRIMEM["Greenwich",0],
UNIT["degree",0.0174532925199433]]
MODULE: String (8.0)
CFCC: String (3.0)
FENAME: String (30.0)
FETYPE: String (4.0)
I'm running mapserver version 4.6.0, should I upgrade to 4.8.0?
The shape is a small file, 50K, so I can provide it if need be.
thanks
Jerl
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060203/a0000b17/attachment.html
