tile4ms question
Jerl Simpson jerl.simpso at GMAIL.COM
Fri Feb 3 15:58:51 EST 2006
Also, ogrinfo reads it all fine, but ogr2ogr can't do anything with it
anymore.  And it was created using ogr2ogr.
On 2/3/06, Ed McNierney <ed at topozone.com> wrote:
> Jerl -
> Do you have a .shx and .dbf file for it, too?  Can you look at a file in
> the same or nearby directory that DOES work to see if you can detect any
> difference?
>      - Ed
> Ed McNierney
> President and Chief Mapmaker
> TopoZone.com / Maps a la carte, Inc.
> 73 Princeton Street, Suite 305
> North Chelmsford, MA  01863
> ed at topozone.com
> (978) 251-4242
> *From:* UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] *On
> Behalf Of *Jerl Simpson
> *Sent:* Friday, February 03, 2006 2:37 PM
> *To:* MAPSERVER-USERS at LISTS.UMN.EDU
> *Subject:* Re: [UMN_MAPSERVER-USERS] tile4ms question
> Just an update, I upgraded to mapserver 4.8.0 and tried using the tile4ms
> provided, with the same result.
> If anyone has any ideas I'd greatly appreciate any help you might be able
> to give.
> Thanks,
> Jerl
> On 2/3/06, Jerl Simpson <jerl.simpso at gmail.com> wrote:
> > I'm not sure if this should be posted here or not, if not please point
> > me to the right place.
> > I'm having trouble with tile4ms opening the files from at least one of
> > my Metafile.txt files.
> > The command I run is as follows:
> > tile4ms Metafile.txt tileindex
> > error is:
> > Aborted. Unable to open
> > SHP:/var/mapping/tiger_2005/PriRoad/tiles/PriRoad_0037.200_-105.400
> > I thought maybe my filename was too long, but I checked the source, 255
> > is the max.  So I'm OK there.
> > ogrinfo has this to say about the file:
> > Layer name: PriRoad_0037.200_-105.400
> > Geometry: Line String
> > Feature Count: 459
> > Extent: (-104.835908, 36.412144) - (-104.424129, 37.988177)
> > Layer SRS WKT:
> > GEOGCS["NAD83",
> >     DATUM["North_American_Datum_1983",
> >         SPHEROID["GRS 1980",6378137,298.257222101 ]],
> >     PRIMEM["Greenwich",0],
> >     UNIT["degree",0.0174532925199433]]
> > MODULE: String (8.0)
> > CFCC: String (3.0)
> > FENAME: String (30.0)
> > FETYPE: String (4.0)
> > I'm running mapserver version 4.6.0, should I upgrade to 4.8.0?
> > The shape is a small file, 50K, so I can provide it if need be.
> > thanks
> > Jerl
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060203/0b94d51b/attachment.html
