tile4ms question
Ed McNierney
ed at TOPOZONE.COM
Fri Feb 3 16:38:36 EST 2006
Did you look at my second question? That's a slightly funky-looking
filename, and I would suspect that might be part of the problem unless
you are having no trouble with similarly-named files.
- Ed
Ed McNierney
President and Chief Mapmaker
TopoZone.com / Maps a la carte, Inc.
73 Princeton Street, Suite 305
North Chelmsford, MA 01863
ed at topozone.com
(978) 251-4242
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
Behalf Of Jerl Simpson
Sent: Friday, February 03, 2006 3:59 PM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: Re: [UMN_MAPSERVER-USERS] tile4ms question
Also, ogrinfo reads it all fine, but ogr2ogr can't do anything with it
anymore. And it was created using ogr2ogr.
On 2/3/06, Ed McNierney < ed at topozone.com <mailto:ed at topozone.com> >
wrote:
Jerl -
Do you have a .shx and .dbf file for it, too? Can you look at a
file in the same or nearby directory that DOES work to see if you can
detect any difference?
- Ed
Ed McNierney
ed at topozone.com
(978) 251-4242
[mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On Behalf Of Jerl Simpson
Sent: Friday, February 03, 2006 2:37 PM
Just an update, I upgraded to mapserver 4.8.0 and tried using
the tile4ms provided, with the same result.
If anyone has any ideas I'd greatly appreciate any help you
might be able to give.
Thanks,
Jerl
On 2/3/06, Jerl Simpson <jerl.simpso at gmail.com> wrote:
I'm not sure if this should be posted here or not, if
not please point me to the right place.
I'm having trouble with tile4ms opening the files from
at least one of my Metafile.txt files.
The command I run is as follows:
tile4ms Metafile.txt tileindex
error is:
Aborted. Unable to open
SHP:/var/mapping/tiger_2005/PriRoad/tiles/PriRoad_0037.200_-105.400
I thought maybe my filename was too long, but I checked
the source, 255 is the max. So I'm OK there.
ogrinfo has this to say about the file:
Layer name: PriRoad_0037.200_-105.400
Geometry: Line String
Feature Count: 459
Extent: (-104.835908, 36.412144) - (-104.424129,
37.988177)
Layer SRS WKT:
GEOGCS["NAD83",
DATUM["North_American_Datum_1983",
SPHEROID["GRS 1980",6378137,298.257222101 ]],
PRIMEM["Greenwich",0],
UNIT["degree",0.0174532925199433]]
MODULE: String (8.0)
CFCC: String (3.0)
FENAME: String (30.0)
FETYPE: String (4.0)
I'm running mapserver version 4.6.0, should I upgrade to
4.8.0?
The shape is a small file, 50K, so I can provide it if
need be.
thanks
Jerl
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060203/e7117513/attachment.html
