chameleon
Hudson, Mark (xwave)
Mark.Hudson at XWAVE.COM
Fri Feb 3 14:30:04 EST 2006
Hi:
I have a chameleon application and am wondering how to manipulate the
legend and query results. My legend is including every layer in my
mapfile - but I want to remove a couple of layers from it (layers that
represent street borders) - not sure how to remove items (layers) from
the legend. Any suggestions?
Secondly, I can get the query results to display for my chosen layer
(crime) by implementing the TEMPLATE object in the mapfile. However, it
does not appear to be reading the template file correctly. I have
specified a TEMPLATE, HEADER, AND FOOTER object in the crime layer but
my TEMPLATE html file specifies chosen fields that should be displayed.
The problem is that every field in the shapefile is being shown in the
query results. The application does not appear to be reading the
template files correctly, but does not work if I do not specify any
templates. Code is below:
Mapfile layer object code:
#layer
LAYER
NAME "Crime Locations"
STATUS ON
DATA "geocode_crime_84"
TYPE POINT
MAXSCALE 100000
TOLERANCE 10
CLASS
STYLE
SYMBOL 'triangle'
COLOR 255 0 0
MINSIZE 8
END
TEMPLATE "../templates/crime_query.html"
END
HEADER "../templates/crime_header.html"
FOOTER "../templates/crime_footer.html"
END
Crime_query.html code:
<tr>
<td>[lrn]</td>
<td>[OFFENCE]</td>
<td>[MODE_TRAVE]</td>
<td>[LOCATION]</td>
<td>[TIME]</td>
<td>[DAY]</td>
<td>[DATE_]</td>
<td>[MONTH]</td>
<td>[WEAPON_USE]</td>
</tr>
Crime_header.html code:
<b>Layer: crime</b>
<p>
<table cellpadding=5 cellspacing=2 border=0>
<tr bgcolor=#CCCCCC>
<td bgcolor=#ffffff> </td>
<th>OFFENCE</th>
<th>MODE_TRAVE</th>
<th>LOCATION</th>
<th>TIME</th>
<th>DAY</th>
<th>DATE_</th>
<th>MONTH</th>
<th>WEAPON_USE</th>
</tr>
Crime_footer.html code:
</table>
<p>
Any suggestions would be helpful. Thanks.
Mark.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060203/c74fc156/attachment.html
