WFS using xml
Eijnden, B. van den (Bart) b.vdeijnden at AGI.RWS.MINVENW.NL
Mon Feb 6 08:18:41 EST 2006
Hi Fabio,
Please always reply to the list.
You can send it eg with Python, or PHP, whatever. You cannot use a pure HTML
form without server-side processing, since it sends using a param=value
approach (i.e. you need to remove the part before the = of the posted string
if I remember correctly).
What do you mean with: "How can I give to the server the XML path?" ?
Example for Python:
import httplib, urllib, string, base64, time
# 1) set variable for request to be posted
request="""
<GetFeature service="WFS" version="1.0.0" xmlns="http://www.opengis.net/wfs"
xmlns:gml="http://www.opengis.net/gml"
xmlns:ogc="http://www.opengis.net/ogc"
xmlns:xlink="http://www.w3.org/1999/xlink"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xsi:schemaLocation="http://schemas.opengis.net/wfs/1.0.0
WFS-basic.xsd"><Query
typeName="postcode"><ogc:Filter><ogc:And><ogc:PropertyIsLike wildCard='*'
singleChar='.' escape='!'
matchCase='false'><ogc:PropertyName>PC6</ogc:PropertyName><ogc:Literal>8044P
C*</ogc:Literal></ogc:PropertyIsLike><ogc:PropertyIsLike wildCard='*'
matchCase='false'><ogc:PropertyName>HUISNR</ogc:PropertyName><ogc:Literal>*<
/ogc:Literal></ogc:PropertyIsLike></ogc:And></ogc:Filter></Query></GetFeatur
e>
# 2) set WFS servername and hostname
# productie
server="/stragisweb/cgi-bin/mapserv.exe?map=/ms4w/apps/stragisweb/htdocs/sit
es/zwolle/map/stragisweb.map&"
hostname="localhost:8080"
# 3) execute the request
h = httplib.HTTP(hostname)
h.putrequest("POST", server)
h.putheader("Content-type", "text/xml")
h.putheader("Content-length", "%d" % len(request))
h.putheader("Accept", "text/xml")
h.putheader('Host', hostname)
h.endheaders()
h.send(request)
reply, msg, hdrs = h.getreply()
# 4) print the response
print h.getfile().read()
Best regards,
Bart
-----Oorspronkelijk bericht-----
Van: fabio.dovidio at planetek.it [mailto:fabio.dovidio at planetek.it]
Verzonden: maandag 6 februari 2006 14:17
Aan: Eijnden, B. van den (Bart)
Onderwerp: Re: [UMN_MAPSERVER-USERS] WFS using xml
How can i send the XML file? Wich is the html form ? How can I give to the
server the XML
path?
Thank u much,
Fabio.
On 6 Feb 2006 at 4:44, Eijnden, B. van den (Bart) wrote:
> Yes this is possible.
> If it does not work posting to the URL you provided, try posting to a URL
> like:
> http://localhost:8089/cgi-bin/mapserv?service=WFS&version=1.0.0
> Best regards,
> Bart
> Van: UMN MapServer Users List
> [mailto:MAPSERVER-USERS at LISTS.UMN.EDU]Namens Ricaille Tanguy
> Verzonden: maandag 6 februari 2006 13:31
> Aan: MAPSERVER-USERS at LISTS.UMN.EDU
> Onderwerp: [UMN_MAPSERVER-USERS] WFS using xml
> Hello,
> is it possible to get a feature description using POST with a xml file
like
> this:
> <wfs:GetFeature service="WFS" version="1.0.0" outputFormat="GML2"...
> xmlns=...
>     <wfs:Query typeName="featurename">
>         <ogc:Filter>
>             <ogc:BBOX>
>                 <ogc:PropertyName>....
> </wfs:GetFeature>
> Can i post it to http://localhost:8089/cgi-bin/mapserv, and get back
> description file in gml ?
> I have a like application using geoserver, and i will try to use
> mapserver... I hope it is possible.
> Thank you.
> Disclaimer
> Aan dit bericht kunnen geen rechten worden ontleend. Dit bericht is
> uitsluitend bestemd voor de geadresseerde. Als u dit bericht per abuis
> hebt ontvangen, wordt u verzocht het te vernietigen en de afzender te
> informeren. Wij adviseren u om bij twijfel over de juistheid of de
> volledigheid van de mail contact met afzender op te nemen.
> This message shall not constitute any rights or obligations.
> This message is intended solely for the addressee.
> If you have received this message in error, please delete it and
> notify the sender immediately. When in doubt whether this message
> is correct or complete, please contact the sender.
Disclaimer
