WFS using xml
Eijnden, B. van den (Bart)
b.vdeijnden at AGI.RWS.MINVENW.NL
Mon Feb 6 09:03:31 EST 2006
WFS 1.0.0 in combination with GML 2.1.2. But Mapserver can also output GML3.
See:
http://mapserver.gis.umn.edu/docs/howto/wfs_server
Best regards,
Bart
-----Oorspronkelijk bericht-----
Van: Ricaille Tanguy [mailto:tanguy.ricaille at trasys.lu]
Verzonden: maandag 6 februari 2006 14:50
Aan: Eijnden, B. van den (Bart); MAPSERVER-USERS at LISTS.UMN.EDU
Onderwerp: Re: [UMN_MAPSERVER-USERS] WFS using xml
Hello and thanks.
It's ok.
Can you also tell me the version of WFS and GML supported by mapserver ?
Best regards,
Tanguy.
----- Original Message -----
From: "Eijnden, B. van den (Bart)" <b.vdeijnden at AGI.RWS.MINVENW.NL>
To: <MAPSERVER-USERS at LISTS.UMN.EDU>
Sent: Monday, February 06, 2006 1:44 PM
Subject: Re: [UMN_MAPSERVER-USERS] WFS using xml
> Yes this is possible.
> If it does not work posting to the URL you provided, try posting to a URL
> like:
> http://localhost:8089/cgi-bin/mapserv?service=WFS&version=1.0.0
> Best regards,
> Bart
> Van: UMN MapServer Users List
> [mailto:MAPSERVER-USERS at LISTS.UMN.EDU]Namens Ricaille Tanguy
> Verzonden: maandag 6 februari 2006 13:31
> Aan: MAPSERVER-USERS at LISTS.UMN.EDU
> Onderwerp: [UMN_MAPSERVER-USERS] WFS using xml
> Hello,
> is it possible to get a feature description using POST with a xml file
like
> this:
> <wfs:GetFeature service="WFS" version="1.0.0" outputFormat="GML2"...
> xmlns=...
> <wfs:Query typeName="featurename">
> <ogc:Filter>
> <ogc:BBOX>
> <ogc:PropertyName>....
> </wfs:GetFeature>
> Can i post it to http://localhost:8089/cgi-bin/mapserv, and get back
> description file in gml ?
> I have a like application using geoserver, and i will try to use
> mapserver... I hope it is possible.
> Thank you.
> Disclaimer
> Aan dit bericht kunnen geen rechten worden ontleend. Dit bericht is
> uitsluitend bestemd voor de geadresseerde. Als u dit bericht per abuis
> hebt ontvangen, wordt u verzocht het te vernietigen en de afzender te
> informeren. Wij adviseren u om bij twijfel over de juistheid of de
> volledigheid van de mail contact met afzender op te nemen.
> This message shall not constitute any rights or obligations.
> This message is intended solely for the addressee.
> If you have received this message in error, please delete it and
> notify the sender immediately. When in doubt whether this message
> is correct or complete, please contact the sender.
Disclaimer
