WFS using xml
Kralidis,Tom [Burlington]
Tom.Kralidis at EC.GC.CA
Mon Feb 6 09:12:38 EST 2006
Hi Bart,
We replied almost identically and at the same time. I see great minds
think alike :)
Tell me, does MapServer CVS work for you? I can't get anything from
CVS, and wanted to check that it's not my network security before I
bother the list.
> -----Original Message-----
> From: UMN MapServer Users List
> [mailto:MAPSERVER-USERS at lists.umn.edu] On Behalf Of Eijnden,
> B. van den (Bart)
> Sent: Monday, February 06, 2006 9:04 AM
> To: MAPSERVER-USERS at lists.umn.edu
> Subject: Re: [UMN_MAPSERVER-USERS] WFS using xml
> WFS 1.0.0 in combination with GML 2.1.2. But Mapserver can
> also output GML3.
> See:
> http://mapserver.gis.umn.edu/docs/howto/wfs_server
> Best regards,
> Bart
> -----Oorspronkelijk bericht-----
> Van: Ricaille Tanguy [mailto:tanguy.ricaille at trasys.lu]
> Verzonden: maandag 6 februari 2006 14:50
> Aan: Eijnden, B. van den (Bart); MAPSERVER-USERS at LISTS.UMN.EDU
> Onderwerp: Re: [UMN_MAPSERVER-USERS] WFS using xml
> Hello and thanks.
> It's ok.
> Can you also tell me the version of WFS and GML supported by
> mapserver ? Best regards, Tanguy.
> ----- Original Message -----
> From: "Eijnden, B. van den (Bart)" <b.vdeijnden at AGI.RWS.MINVENW.NL>
> To: <MAPSERVER-USERS at LISTS.UMN.EDU>
> Sent: Monday, February 06, 2006 1:44 PM
> > Yes this is possible.
> > If it does not work posting to the URL you provided, try
> posting to a
> > URL
> > like:
> > http://localhost:8089/cgi-bin/mapserv?service=WFS&version=1.0.0
> > Best regards,
> > Bart
> > Van: UMN MapServer Users List
> > [mailto:MAPSERVER-USERS at LISTS.UMN.EDU]Namens Ricaille Tanguy
> > Verzonden: maandag 6 februari 2006 13:31
> > Aan: MAPSERVER-USERS at LISTS.UMN.EDU
> > Onderwerp: [UMN_MAPSERVER-USERS] WFS using xml
> > Hello,
> > is it possible to get a feature description using POST with
> a xml file
> like
> > this:
> > <wfs:GetFeature service="WFS" version="1.0.0"
> outputFormat="GML2"...
> > xmlns=...
> > <wfs:Query typeName="featurename">
> > <ogc:Filter>
> > <ogc:BBOX>
> > <ogc:PropertyName>....
> > </wfs:GetFeature>
> > Can i post it to http://localhost:8089/cgi-bin/mapserv, and
> get back
> > description file in gml ?
> > I have a like application using geoserver, and i will try to use
> > mapserver... I hope it is possible. Thank you.
> > Disclaimer
> > Aan dit bericht kunnen geen rechten worden ontleend. Dit bericht is
> > uitsluitend bestemd voor de geadresseerde. Als u dit
> bericht per abuis
> > hebt ontvangen, wordt u verzocht het te vernietigen en de
> afzender te
> > informeren. Wij adviseren u om bij twijfel over de juistheid of de
> > volledigheid van de mail contact met afzender op te nemen.
> > This message shall not constitute any rights or obligations. This
> > message is intended solely for the addressee. If you have received
> > this message in error, please delete it and notify the sender
> > immediately. When in doubt whether this message is correct or
> > complete, please contact the sender.
> Disclaimer
> bericht is uitsluitend bestemd voor de geadresseerde. Als u
> dit bericht per abuis hebt ontvangen, wordt u verzocht het te
> vernietigen en de afzender te
> This message is intended solely for the addressee. If you
> have received this message in error, please delete it and
> notify the sender immediately. When in doubt whether this
> message is correct or complete, please contact the sender.
