WFS using xml
Kralidis,Tom [Burlington] Tom.Kralidis at EC.GC.CA
Mon Feb 6 09:16:43 EST 2006
Lovely, I intended to reply to Bart only but my fumble ended up in a
list-wide email :)
Anyways, is CVS down?
> -----Original Message-----
> From: UMN MapServer Users List
> [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On Behalf Of
> Sent: Monday, February 06, 2006 9:13 AM
> To: MAPSERVER-USERS at LISTS.UMN.EDU
> Subject: Re: [UMN_MAPSERVER-USERS] WFS using xml
> Hi Bart,
> We replied almost identically and at the same time.  I see
> great minds think alike :)
> Tell me, does MapServer CVS work for you?  I can't get
> anything from CVS, and wanted to check that it's not my
> network security before I bother the list.
> > [mailto:MAPSERVER-USERS at lists.umn.edu] On Behalf Of Eijnden,
> > B. van den (Bart)
> > Sent: Monday, February 06, 2006 9:04 AM
> > To: MAPSERVER-USERS at lists.umn.edu
> > WFS 1.0.0 in combination with GML 2.1.2. But Mapserver can
> > also output GML3.
> > See:
> > http://mapserver.gis.umn.edu/docs/howto/wfs_server
> > Best regards,
> > Bart
> > -----Oorspronkelijk bericht-----
> > Van: Ricaille Tanguy [mailto:tanguy.ricaille at trasys.lu]
> > Verzonden: maandag 6 februari 2006 14:50
> > Aan: Eijnden, B. van den (Bart); MAPSERVER-USERS at LISTS.UMN.EDU
> > Onderwerp: Re: [UMN_MAPSERVER-USERS] WFS using xml
> > Hello and thanks.
> > It's ok.
> > Can you also tell me the version of WFS and GML supported by
> > mapserver ? Best regards, Tanguy.
> > ----- Original Message -----
> > From: "Eijnden, B. van den (Bart)" <b.vdeijnden at AGI.RWS.MINVENW.NL>
> > To: <MAPSERVER-USERS at LISTS.UMN.EDU>
> > Sent: Monday, February 06, 2006 1:44 PM
> > > Yes this is possible.
> > > If it does not work posting to the URL you provided, try
> > posting to a
> > > URL
> > > like:
> > > http://localhost:8089/cgi-bin/mapserv?service=WFS&version=1.0.0
> > > Best regards,
> > > Bart
> > > Van: UMN MapServer Users List
> > > [mailto:MAPSERVER-USERS at LISTS.UMN.EDU]Namens Ricaille Tanguy
> > > Verzonden: maandag 6 februari 2006 13:31
> > > Aan: MAPSERVER-USERS at LISTS.UMN.EDU
> > > Onderwerp: [UMN_MAPSERVER-USERS] WFS using xml
> > > Hello,
> > > is it possible to get a feature description using POST with
> > a xml file
> > like
> > > this:
> > > <wfs:GetFeature service="WFS" version="1.0.0"
> > outputFormat="GML2"...
> > > xmlns=...
> > >     <wfs:Query typeName="featurename">
> > >         <ogc:Filter>
> > >             <ogc:BBOX>
> > >                 <ogc:PropertyName>....
> > > </wfs:GetFeature>
> > > Can i post it to http://localhost:8089/cgi-bin/mapserv, and
> > get back
> > > description file in gml ?
> > > I have a like application using geoserver, and i will try to use
> > > mapserver... I hope it is possible. Thank you.
> > > Disclaimer
> > > Aan dit bericht kunnen geen rechten worden ontleend. Dit
> bericht is
> > > uitsluitend bestemd voor de geadresseerde. Als u dit
> > bericht per abuis
> > > hebt ontvangen, wordt u verzocht het te vernietigen en de
> > afzender te
> > > informeren. Wij adviseren u om bij twijfel over de
> juistheid of de
> > > volledigheid van de mail contact met afzender op te nemen.
> > > This message shall not constitute any rights or obligations. This
> > > message is intended solely for the addressee. If you have
> received
> > > this message in error, please delete it and notify the sender
> > > immediately. When in doubt whether this message is correct or
> > > complete, please contact the sender.
> > Disclaimer
> > bericht is uitsluitend bestemd voor de geadresseerde. Als u
> > dit bericht per abuis hebt ontvangen, wordt u verzocht het te
> > vernietigen en de afzender te
> > informeren. Wij adviseren u om bij twijfel over de juistheid of de
> > This message is intended solely for the addressee. If you
> > have received this message in error, please delete it and
> > notify the sender immediately. When in doubt whether this
> > message is correct or complete, please contact the sender.
