Export data to Shape, DGN, DWG, ...
Eijnden, B. van den (Bart) b.vdeijnden at AGI.RWS.MINVENW.NL
Mon Feb 6 10:07:10 EST 2006
Just do a GetFeature request to Mapserver WFS, you get back GML. Use ogr2ogr
to convert to shape or DWG. Note ogr2ogr has no writing capability for DGN,
and for DWG write you need to have a valid copy of the OpenDesign Alliance
library.
See also:
http://www.gdal.org/ogr/drv_dxfdwg.html
Best regards,
Bart
-----Oorspronkelijk bericht-----
Van: UMN MapServer Users List
[mailto:MAPSERVER-USERS at LISTS.UMN.EDU]Namens Davelaar, Hilbert
Verzonden: maandag 6 februari 2006 16:05
Aan: MAPSERVER-USERS at LISTS.UMN.EDU
Onderwerp: [UMN_MAPSERVER-USERS] Export data to Shape, DGN, DWG, ...
Hi list,
Can someone tell me if it's possible (and how) to export data served by
MapServer as WMS or WFS to for example Shape, DGN of DWG format?
Regards,
Hilbert Davelaar
Disclaimer
Aan dit bericht kunnen geen rechten worden ontleend. Dit bericht is
uitsluitend bestemd voor de geadresseerde. Als u dit bericht per abuis
hebt ontvangen, wordt u verzocht het te vernietigen en de afzender te
informeren. Wij adviseren u om bij twijfel over de juistheid of de
volledigheid van de mail contact met afzender op te nemen.
This message shall not constitute any rights or obligations.
This message is intended solely for the addressee.
If you have received this message in error, please delete it and
notify the sender immediately. When in doubt whether this message
is correct or complete, please contact the sender.
