Visualizing Point Data
Bob Basques bob.b at GRITECHNOLOGIES.COM
Tue Feb 7 01:44:51 EST 2006
Bill,
The census site I sent you is actually doing this type of overlay right
now.  It's all MapServer/Mapscript based. Let me know if you have any
questions.
The overlays are drawn on the fly from the Census BlockGroup data.
It's got quite a bit of indexing behind the scenes that makes it run
fairly quickly.   It seems to run out of steam at around 50k points when
the time seems to take a jump up to 10-15 seconds to process ( the limit
we were shooting for).  Unfortunately, the code is very Census specific
at the moment.   We're planning on chopping the code out into a tool
set, just haven't had time yet.
One other item, the overlays are being drawn right now in a fairly
course grid, the overlay drawing aspects are configurable and the
resolution can be increased at the cost of time for processing.
bobb
Bill Binko wrote:
>On Fri, 2006-02-03 at 11:40 -0800, Dylan Beaudette wrote:
>>I was just working on this last night:
>>http://casoilresource.lawr.ucdavis.edu/drupal/node/172
>>check out the source for v.kernel in GRASS
>Dylan,
>This is an excellent example of what I'm trying to achieve.  Here are
>some quick thoughts about what you've shown:
>1) How would you publish this "live" to the web?  Do you know how to
>integrate v.kernel to push its output to mapserver directly?  I know
>there are tools to push GRASS output through GDAL, and I suspect that
>that could be daisy chained into mapserver, but I'd like someone's
>opinion who's actually done this.  If there's an example (anybody?) or
>HOWTO of how to leverage GRASS this way?
>2) What is the performance of v.kernel.  For example, I'll have 30-100K
>points over the state of florida.  For a zoomed out view, how long would
>that take to draw?  Perhaps a better question would be, what is the
>order of complexity of the approach taken by GRASS.
>3) Unfortunately, because I may want to integrate this into Mapserver, I
>can't quite look at the GRASS source on this.  More specifically, I
>can't copy it since it's GPL into Mapserver, which is BSD and then
>distribute it. Now: I may choose to simply write code to call GRASS
>externally, but I wouldn't need to explore the source for that.
>I will however, get GRASS 6 up and running here so that I can explore
>it.  Thanks for the pointer.
>Bill
>Bill Binko <bill at binko.net>
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060207/f4cca303/attachment.html
