Rahkonen Jukka
Jukka.Rahkonen at MMMTIKE.FI
Tue Feb 7 05:24:45 EST 2006
Hi Sture,
I suggest you to test first with a browser if Mapserver is actually sending
the vectors. If not, for me the reason is usually wrong extents in map-file.
Something like this should show you vectors on a browser:
http://localhost/cgi-bin/mapserv.exe?map=d:/ms4w/apps/ms101/data/wfstest.map&mode=map
It that works, you can next try a WFS request with your browser like:
http://localhost/cgi-bin/mapserv.exe?map=d:/ms4w/apps/ms101/data/jukkawfs.map&SERVICE=WFS&VERSION=1.0.0&REQUEST=getfeature&TYPENAME=jukka
If you get something that looks like valid GML then you know that
quite a lot is OK on MapServer side.
-Jukka-
My simple mapfile follows:
MAP
NAME WFS-MAP
STATUS ON
EXTENT 2464000.000 6779500.000 2467000.000 6780000.000
SIZE 1000 800
UNITS METERS
SHAPEPATH "d:/ms4w/apps/ms101/data"
IMAGECOLOR 255 255 255
WEB
IMAGEPATH "d:/ms4w/apps/ms101/data"
IMAGEURL "/MS_TMP/"
METADATA
"wfs_title" "JRA-test-WFS"
"wfs_onlineresource" "http://localhost/cgi-bin/mapserv.exe?map=d:/ms4w/apps/ms101/data/jukkawfs.map"
"wfs_srs" "EPSG:2392"
END
END
PROJECTION
"init=epsg:2392"
END
LAYER
NAME jukka
METADATA
"wfs_title" "Parcels"
"gml_include_items" "all"
END
TYPE POLYGON
DATA jukka.shp
PROJECTION
"init=epsg:2393"
END
DUMP TRUE
STATUS DEFAULT
CLASS
NAME "jukka"
OUTLINECOLOR 0 0 0
END
END
END
Lähettäjä: UMN MapServer Users List puolesta: Sture Dingsøyr
Lähetetty: ti 7.2.2006 0:27
Vastaanottaja: MAPSERVER-USERS at LISTS.UMN.EDU
Aihe: [UMN_MAPSERVER-USERS]
Hi
I am testing the WFS server on Mapserver.
I am running on Windows (4.6.2)
Have set up WMS and this works just fine (getCapabilities, getMap and getFeatureInfo).
I have set up a simple mapfile to server WFS, and my getcapabilities request seems to work. It returns XML listing the layers in my WFS mapfile.
But when I try to make a getFeature request it only returns this:
<?xml version="1.0" encoding="ISO-8859-1" ?>
<wfs:FeatureCollection xmlns:myns="http://www.ttt.org/myns" xmlns:wfs="http://www.opengis.net/wfs" xmlns:gml="http://www.opengis.net/gml" xmlns:ogc="http://www.opengis.net/ogc" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://www.opengis.net/wfs http://schemas.opengeospatial.net/wfs/1.0.0/WFS-basic.xsd http://www.ttt.org/myns http://avsdi/adaptive/wfs.aspx?SERVICE=WFS&VERSION=1.0.0&REQUEST=DescribeFeatureType&TYPENAME=Omverda&OUTPUTFORMAT=XMLSCHEMA">
<gml:boundedBy>
<gml:null>missing</gml:null>
</gml:boundedBy>
</wfs:FeatureCollection>
It says <gml:null>missing</gml:null>.
What is missing?
Anybody got any ideas?
Regards
Sture
