MapServer WFS Client: POST body is shor t
Eijnden, B. van den (Bart) b.vdeijnden at AGI.RWS.MINVENW.NL
Tue Feb 7 05:44:00 EST 2006
Jukka,
he is using version 4.6.1 which did not have the bug introduced just after
4.8 RC3, so this is not related to that particular issue.
Martijn, you could try upgrading to Mapserver 4.8.1 though and see if the
problem still exists.
Best regards,
Bart
-----Oorspronkelijk bericht-----
Van: UMN MapServer Users List
[mailto:MAPSERVER-USERS at LISTS.UMN.EDU]Namens Rahkonen Jukka
Verzonden: dinsdag 7 februari 2006 11:42
Aan: MAPSERVER-USERS at LISTS.UMN.EDU
Onderwerp: Re: [UMN_MAPSERVER-USERS] MapServer WFS Client: POST body is
short
Isn't this just something that was corrected to version 4.8.1? See some
postings with title "MapServer 4.8.1 released" to check that.
-Jukka-
Lähettäjä: UMN MapServer Users List puolesta: mvexel (sent by Nabble.com)
Lähetetty: ti 7.2.2006 12:32
Vastaanottaja: MAPSERVER-USERS at LISTS.UMN.EDU
Aihe: [UMN_MAPSERVER-USERS] MapServer WFS Client: POST body is short
Hi mapserver-users,
This might be more of a MapInfo-related problem than anything else, but I
can't really pin it to MapInfo so here it goes;
I'm using MapInfo 8.0 to try and connect to my Mapserver 4.6.1-based WFS
Server.
I feed MapInfo the URL:
http://testserver/cgi-bin/mapserv.exe?map=/wfs_klic.map&
MapInfo successfully performs and parses a GetCapabilities request. I get
the one layer I defined in the layers list. But when I click on that layer I
get a
POST body is short
MapInfo suggests it has something to do with a failed DescribeFeatureType
request. Is this a MapServer-related thing or is the MapInfo client still
flaky?
Thanks,
Martijn van Exel
Bridgis BV
View this message in context: MapServer WFS Client: POST body is short
<http://www.nabble.com/MapServer-WFS-Client%3A-POST-body-is-short-t1075127.h
tml#a2798730>
Sent from the Mapserver - User
<http://www.nabble.com/Mapserver---User-f1215.html>  forum at Nabble.com.
Disclaimer
Aan dit bericht kunnen geen rechten worden ontleend. Dit bericht is
uitsluitend bestemd voor de geadresseerde. Als u dit bericht per abuis
hebt ontvangen, wordt u verzocht het te vernietigen en de afzender te
informeren. Wij adviseren u om bij twijfel over de juistheid of de
volledigheid van de mail contact met afzender op te nemen.
This message shall not constitute any rights or obligations.
This message is intended solely for the addressee.
If you have received this message in error, please delete it and
notify the sender immediately. When in doubt whether this message
is correct or complete, please contact the sender.
