.NET Framework SDk 2.0
E Witteveen eywitteveen at GMAIL.COM
Tue Feb 7 09:39:52 EST 2006
Fabio D' Ovidio wrote:
 > Does MapServer 4.4.1 support .NET Framework SDK 2.0 ?
I've made a small mapfile editor in .NET 2.0 using the mapserver csharp
api. It appears to be working, but there are some issues with it(using 4.6).
On http://www.nergens.org/projects/mapviewer/ (currently being updated,
at 19 hours GMT it should be working again) you can find the source
files and the binary. This exercise was just to see if i could get it
working together, so don't expect anything fancy :D
Maybe the tread
http://www.mail-archive.com/mapserver-users@lists.umn.edu/msg02637.html
can help you a little bit more,..
