OracleSpatial and polygons crossing the antimeridian
Frank Warmerdam
warmerdam at POBOX.COM
Tue Feb 7 11:13:25 EST 2006
On 2/7/06, John Cartwright <John.C.Cartwright at noaa.gov> wrote:
> Hello All,
> I have a single polygon in oracle spatial (10.1) which crosses the
> antimeridian. Displaying this polygon in an unprojected map (WGS84),
> shows the polygon incorrectly stretching across the globe in the
> longitude coordinate. This is not entirely unexpected. However, when I
> switch to an orthographic projection, I don't see the polygon displayed
> at all which suprises me.
> This looks like a symptom of bug 411 which was marked as resolved.
> Oracle itself seems to be treating the poly correctly since the geometry
> validates and a SDO_FILTER query returns the correct results.
> Should mapserver be able to handle polygons which cross the
> antimeridian? I'm using mapserver 4.8.1 and the oraclespatial
> connection type.
John,
If you could prepare an example reproducing this
problem with the geometry as an inline feature, and
submit that through bugzilla, I am willing to take a look.
In theory this should work, but there are a number of points
at which things might be getting screwed up.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
