.NET Framework SDk 2.0
Piero Cavalieri
piero.cavalieri at HEIDI.IT
Tue Feb 7 12:46:37 EST 2006
Fabio D' Ovidio ha scritto:
> Does MapServer 4.4.1 support .NET Framework SDK 2.0 ?
I don't know if C# MapScript works with .NET 2, but you can work both in
BROWSE and *QUERY* mode using cgi. There are no threading issues except
Mapserver cgi itself (I suppose).
For example, using Ajax .NET
(http://ajax.schwarz-interactive.de/csharpsample/default.aspx)
something like this (only an idea, not complete and raw):
Main .aspx page:
//using dbox
function setbox_handler(name, minx, miny, maxx, maxy) {
document.mapserv.imgbox.value = minx + " " + miny + " " + maxx
+ " " + maxy;
document.mapserv.imgxy.value = minx + " " + miny;
//document.forms[0].submit(); <-- old form style
retrieveMap(); <-- new Ajax style
<img id=main_image src="" width="" height="">
<input name="ref" type="image" id="referenceMap" src="">
Code behind:
if(!IsPostBack) {
// Register the class that will hold the
methods.
BorgWorX.Web.Core.Ajax.Utility.RegisterTypeForAjax(typeof
(mapsrvNet.AjaxMethods), Page);
} else {
file AjaxMethods.js:
var swapMapImageTime = 1000;
//offscreen images, used in preload
var imgMapOff = new Image();
var imgRefOff = new Image();
var queryString;
var layers;
var baseUrl;
var imgxy;
var imgext;
var mapwidth;
var mapheight;
var imgbox;
var zoom = 0;
function retrieveMap()
//recupero lista layers
var childNodes = document.getElementById("layerListDiv");
layerArray = childNodes.getElementsByTagName("input");
//alert(layers.length);
var i;
var layersString = "";
for(i=0; i < layerArray.length; i++) {
if(layerArray[i].checked == true) {
layersString += "&layer=" + layerArray[i].value;
baseUrl = document.getElementById("baseUrl").value;
imgxy = document.getElementById("imgxy").value;
imgext = document.getElementById("imgext").value;
mapwidth = document.getElementById("mapwidth").value;
mapheight = document.getElementById("mapheight").value;
imgbox = document.getElementById("imgbox").value;
//build url
querySting = baseUrl + layersString + "&mode=browse" + "&imgext=" +
imgext + "&imgbox=" + imgbox;
AjaxMethods.RetrieveImage(querySting, retrieveMapImage_callback);
function retrieveMapImage_callback(res)
try {
if(typeof(res.value) == 'object' && res.error == null) {
imgMapOff.src = res.value.mapImgUrl; //preload image
imgRefOff.src = res.value.referenceMap;
setTimeout("updateImg()",swapMapImageTime); //and wait n
seconds for image download
} else {
throw res.error.toString();
} catch (exception) {
this.status = "PROBLEMS RETRIEVING MAP !";
//alert(exception);
function updateImg() {
document.getElementById("main_image").src = imgMapOff.src;
document.getElementById("referenceMap").src = imgRefOff.src;
SERVER SIDE (C#):
file AjaxMethods.cs:
namespace mapsrvNet
/// <summary>
/// Summary description for Methods.
/// </summary>
public class AjaxMethods
//qui devo creare classe Map
[BorgWorX.Web.Core.Ajax.AjaxMethod()]
public Map RetrieveImage(string queryString)
string mapImgUrl = null;
string mapwidth = null;
string mapheight = null;
string scalebar = null;
string imgxy = null; //[center] of the image
string imgext = null;
string legend = null;
string referenceMap = null;
Map map = null; //holds all map value
try {
// Create a 'WebRequest' with the specified
url.
//if(debug)throw new Exception
("queryString: "+queryString);
HttpWebRequest webRequest =
(HttpWebRequest) WebRequest.Create(queryString);
//webRequest.KeepAlive = false;
webRequest.Timeout=10000;
webRequest.Method = "GET";
// Send the WebRequest and read response
HttpWebResponse webResponse =
(HttpWebResponse) webRequest.GetResponse();
Stream sResponse =
webResponse.GetResponseStream();
StreamReader reader = new StreamReader
(sResponse);
//first line is additional info from
string header = reader.ReadLine();
if(header == "<HTML>") {
string message = reader.ReadToEnd();
message += "\n\n\"" + header +
message + "\"\n\n";
throw new Exception(message);
//actual parameters
mapImgUrl = reader.ReadLine();
mapwidth = reader.ReadLine();
mapheight = reader.ReadLine();
scalebar = reader.ReadLine();
imgxy = reader.ReadLine();
imgext = reader.ReadLine();
legend = reader.ReadLine();
referenceMap = reader.ReadLine();
map = new Map(mapImgUrl, mapwidth,
mapheight, scalebar, imgxy, imgext, legend, referenceMap);
sResponse.Close();
reader.Close();
webResponse.Close();
} catch (Exception ex) {
throw new Exception
("queryString:"+queryString+"\n\n"+ex.ToString());
return map;
} //method
} //class
} //namespace
file Map.cs:
namespace mapsrvNet
/// <summary>
/// Description of Map.
/// </summary>
[Serializable]
public class Map
public string mapImgUrl = "";
public string mapwidth = "";
public string mapheight = "";
public string scalebar = "";
public string imgxy = "";
public string imgext = "";
public string legend = "";
public string referenceMap = "";
public Map(string mapImgUrl, string mapwidth, string
mapheight, string scalebar, string imgxy, string imgext, string legend,
string referenceMap)
this.mapImgUrl = mapImgUrl;
this.mapwidth = mapwidth;
this.mapheight = mapheight;
this.scalebar = scalebar;
this.imgxy = imgxy;
this.imgext = imgext;
this.legend = legend;
this.referenceMap = referenceMap;
file web_template.html: (u could use also xml file)
[img]
[mapwidth]
[mapheight]
[scalebar]
[center]
[mapext]
[legend]
[ref]
.Map file:
TEMPLATE "templates/web_template.html"
U work in similar way with query templates.
Bye
Piero
