invalide extension in the wms capability file
Rainer Spittel
rainer.spittel at TERRALINK.CO.NZ
Tue Feb 7 16:59:47 EST 2006
Hi there,
I have a problem with my WMS server. I am using the NZMG (ESPG:27200)
projection and my php client is accessing and visualise the data perfect.
But when I call the WMS service, I get a <inf> value in the extention of the
layers.
I checked the exstension. ogrinfo delivers the used map's extension and
the epsg definition file defines the projection as follow:
# NZGD49 / New Zealand Map Grid
<27200> +proj=nzmg +lat_0=-41 +lon_0=173 +x_0=2510000 +y_0=6023150
+ellps=intl +units=m +no_defs no_defs <>
The mapfile is like this:
MAP
NAME "devServer"
STATUS ON
# New Zealand
EXTENT 2000073 5310090 3001881 6785641
SIZE 640 400
# ---- parameters
SHAPEPATH "/opt/fgs-base/data"
FONTSET "../etc/fonts.txt"
SYMBOLSET "../etc/symbols.sym"
PROJECTION
"init=epsg:27200" # NZMG (temporal projection)
END
WEB
METADATA
wms_title "NZ - Portal DevBox (WMS)"
wms_onlineresource "http://test:8082/cgi-bin/wms_service?"
wms_srs "epsg:27200 epsg:4326"
END
# ---- path
IMAGEPATH "/opt/fgs-base/tmp/ms_tmp/"
IMAGEURL "/ms_tmp/"
LOG "/opt/fgs-base/tmp/ms_tmp/gmap.log"
END
LAYER
NAME "area"
GROUP "Basemap"
STATUS OFF
CONNECTIONTYPE POSTGIS
CONNECTION "host=localhost dbname=... user=... password=..."
DATA "the_geom from (select * from area) as foo USING UNIQUE gid USING
srid=27200"
TYPE POLYGON
# ---- setting up on the fly projection
PROJECTION
"init=epsg:27200"
END
TEMPLATE "ttt.html"
METADATA
wms_title "Area"
END
# ---- classification for graphical visualization
CLASS
NAME "Areal;Areal"
STYLE
COLOR 255 0 0
OUTLINECOLOR 0 0 0
END
END
END
END #Mapfile
Calling the GetCapabilities request delivered following entities in the
extension of the maps:
<?xml version='1.0' encoding="ISO-8859-1" standalone="no" ?>
<!DOCTYPE WMT_MS_Capabilities SYSTEM
"http://schemas.opengeospatial.net/wms/1.1.1/WMS_MS_Capabilities.dtd"
<!ELEMENT VendorSpecificCapabilities EMPTY>
]> <!-- end of DOCTYPE declaration -->
<WMT_MS_Capabilities version="1.1.1">
<!-- MapServer version 4.4.1 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT INPUT=EPPL7 INPUT=POSTGIS INPUT=OGR
INPUT=GDAL INPUT=SHAPEFILE -->
<Service>
<Name>OGC:WMS</Name>
<Title>devServer</Title>
<OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink"
xlink:href="http://test:8082/cgi-bin/wms_service?"/>
</Service>
<Capability>
<Request>
</Request>
<Exception>
</Exception>
<VendorSpecificCapabilities />
<UserDefinedSymbolization SupportSLD="1" UserLayer="0" UserStyle="1"
RemoteWFS="0"/>
<Layer>
<Name>devServer</Name>
<Title>NZ - Portal DevBox (WMS)</Title>
<SRS>epsg:27200 epsg:4326</SRS>
<LatLonBoundingBox minx="166.266" miny="-47.4146" maxx="179.484"
maxy="-34.0029" />
<BoundingBox SRS="EPSG:27200"
minx="2.00007e+06" miny="5.31009e+06" maxx="3.00188e+06"
maxy="6.78564e+06" />
<Layer>
<Layer queryable="1" opaque="0" cascaded="0">
<Name>area</Name>
<Title>Area</Title>
<SRS>EPSG:27200</SRS>
<LatLonBoundingBox minx="-153.889" miny="-75.0898" maxx="121.962"
maxy="inf" />
minx="-2.5e+07" miny="-2.5e+07" maxx="2.5e+07"
maxy="2.5e+07" />
<Style>
<Name>default</Name>
<Title>default</Title>
<LegendURL width="18" height="12">
<Format>image/png</Format>
xlink:type="simple"
xlink:href="http://test:8082/cgi-bin/wms_server?version=1.1.1&service=WMS&request=GetLegendGraphic&layer=b_area&format=image/png"/>
</LegendURL>
</Style>
</Layer>
</Layer>
</Layer>
</Capability>
</WMT_MS_Capabilities>
The entity maxy="inf" in the LatLonBoudningBox field makes big problems for
WMS clients to parse this capability file. What might be wrong on that?
Cheers
Rainer
