invalide extension in the wms capabilit y file
Chris Tweedie chris at NARX.NET
Tue Feb 7 22:59:14 EST 2006
Rainer, depends on your use i guess.
Have a read through all the options at,
http://mapserver.gis.umn.edu/docs/howto/wms_server/?searchterm=wms
Most of the optional paramters are for CITE compliance or other
features (such as WMS-Time and WFS).
So long as your capabilities are reporting the correct online_resource
url and a correct BBOX, most clients should function without any
problems.
Chris
Quoting Rainer Spittel <rainer.spittel at terralink.co.nz>:
> Hi Chris
>  cool, now it works. Thanks a lot.
>  Might there be some more wms-metadata fields I should add except the
> mandatory fields?
> Cheers
> Rainer Spittel
> -----Original Message-----
> From: chris at narx.net [mailto:chris at narx.net]
> Sent: Wednesday, 8 February 2006 2:02 p.m.
> To: Rainer Spittel
> Cc: MAPSERVER-USERS at LISTS.UMN.EDU
> Subject: Re: [UMN_MAPSERVER-USERS] invalide extension in the wms capability
> file
> Rainer,
> try adding the wms_extent parameter to your LAYER / METADATA object.
> This will override the need for MS to try and determine the extents
> from PostGIS, i have had some occasions where the BBOX was reported
> incorrectly (especially from postgis/sde). Just make sure what you
> specify is in the correct SRS.
> eg.
> LAYER ..
> METADATA
> wms_extent "2000073 5310090 3001881 6785641"
> Quoting Rainer Spittel <rainer.spittel at TERRALINK.CO.NZ>:
>> Hi there,
>>  I have a problem with my WMS server. I am using the NZMG (ESPG:27200)
>> projection and my php client is accessing and visualise the data
>> perfect. But when I call the WMS service, I get a <inf> value in the
>> extention of the layers.  I checked the exstension. ogrinfo delivers
>> the used map's extension and the epsg definition file defines the
>> projection as follow:
>> # NZGD49 / New Zealand Map Grid
>> <27200> +proj=nzmg +lat_0=-41 +lon_0=173 +x_0=2510000 +y_0=6023150
>> +ellps=intl +units=m +no_defs  no_defs <>
>> The mapfile is like this:
>> MAP
>>  NAME "devServer"
>>  STATUS ON
>>  # New Zealand
>>  EXTENT 2000073 5310090 3001881 6785641
>>  SIZE 640 400
>>  # ---- parameters
>>  SHAPEPATH "/opt/fgs-base/data"
>>  FONTSET   "../etc/fonts.txt"
>>  SYMBOLSET "../etc/symbols.sym"
>>  PROJECTION
>>    "init=epsg:27200"  # NZMG (temporal projection)
>>  END
>>  WEB
>>    METADATA
>>      wms_title          "NZ - Portal DevBox (WMS)"
>>      wms_onlineresource "http://test:8082/cgi-bin/wms_service?"
>>      wms_srs            "epsg:27200 epsg:4326"
>>    END
>>    # ---- path
>>    IMAGEPATH "/opt/fgs-base/tmp/ms_tmp/"
>>    IMAGEURL  "/ms_tmp/"
>>    LOG       "/opt/fgs-base/tmp/ms_tmp/gmap.log"
>>  END
>>  LAYER
>>    NAME "area"
>>    GROUP "Basemap"
>>    STATUS OFF
>>    CONNECTIONTYPE POSTGIS
>>    CONNECTION "host=localhost dbname=... user=... password=..."
>>    DATA "the_geom from (select * from area) as foo USING UNIQUE gid
>> USING srid=27200"
>>    TYPE POLYGON
>>    # ---- setting up on the fly projection
>>    PROJECTION
>>      "init=epsg:27200"
>>    END
>>    TEMPLATE "ttt.html"
>>    METADATA
>>      wms_title     "Area"
>>    END
>>    # ---- classification for graphical visualization
>>    CLASS
>>      NAME "Areal;Areal"
>>      STYLE
>>        COLOR 255 0 0
>>        OUTLINECOLOR 0 0 0
>>      END
>>    END
>>  END
>> END #Mapfile
>> Calling the GetCapabilities request delivered following entities in
>> the extension of the maps:
>> <?xml version='1.0' encoding="ISO-8859-1" standalone="no" ?> <!DOCTYPE
>> WMT_MS_Capabilities SYSTEM
>> "http://schemas.opengeospatial.net/wms/1.1.1/WMS_MS_Capabilities.dtd"
>> <!ELEMENT VendorSpecificCapabilities EMPTY>
>> ]>  <!-- end of DOCTYPE declaration -->
>> <WMT_MS_Capabilities version="1.1.1">
>> <!-- MapServer version 4.4.1 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG
>> OUTPUT=WBMP SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER
>> SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT
>> INPUT=EPPL7 INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE -->
>> <Service>
>>  <Name>OGC:WMS</Name>
>>  <Title>devServer</Title>
>>  <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink"
>> xlink:href="http://test:8082/cgi-bin/wms_service?"/>
>> </Service>
>> <Capability>
>>  <Request>
>>  </Request>
>>  <Exception>
>>  </Exception>
>>  <VendorSpecificCapabilities />
>>  <UserDefinedSymbolization SupportSLD="1" UserLayer="0" UserStyle="1"
>> RemoteWFS="0"/>  <Layer>
>>    <Name>devServer</Name>
>>    <Title>NZ - Portal DevBox (WMS)</Title>
>>    <SRS>epsg:27200 epsg:4326</SRS>
>>    <LatLonBoundingBox minx="166.266" miny="-47.4146" maxx="179.484"
>> maxy="-34.0029" />
>>    <BoundingBox SRS="EPSG:27200"
>>                minx="2.00007e+06" miny="5.31009e+06" maxx="3.00188e+06"
>> maxy="6.78564e+06" />
>>    <Layer>
>>      <Layer queryable="1" opaque="0" cascaded="0">
>>        <Name>area</Name>
>>        <Title>Area</Title>
>>        <SRS>EPSG:27200</SRS>
>>        <LatLonBoundingBox minx="-153.889" miny="-75.0898" maxx="121.962"
>> maxy="inf" />
>>                    minx="-2.5e+07" miny="-2.5e+07" maxx="2.5e+07"
>> maxy="2.5e+07" />
>>        <Style>
>>          <Name>default</Name>
>>          <Title>default</Title>
>>          <LegendURL width="18" height="12">
>>             <Format>image/png</Format>
>> xlink:type="simple"
> xlink:href="http://test:8082/cgi-bin/wms_server?version=1.1.1&amp;service=WM
> S&amp;request=GetLegendGraphic&amp;layer=b_area&amp;format=image/png"/>
>>          </LegendURL>
>>        </Style>
>>      </Layer>
>>    </Layer>
>>  </Layer>
>> </Capability>
>> </WMT_MS_Capabilities>
>> The entity maxy="inf" in the LatLonBoudningBox field makes big
>> problems for WMS clients to parse this capability file. What might be
>> wrong on that?
>> Cheers
>> Rainer
