Coordinate Systems used in the Netherla nds?
Eijnden, B. van den (Bart)
b.vdeijnden at AGI.RWS.MINVENW.NL
Wed Feb 8 06:42:50 EST 2006
What I normally use is:
PROJECTION
"init=epsg:28992"
END
And in my epsg file I use the following params:
# RD / Netherlands New
<28992> +proj=sterea +lat_0=52.15616055555555 +lon_0=5.38763888888889
+k=0.999908 +x_0=155000 +y_0=463000 +ellps=bessel +units=m
+towgs84=565.2369,50.0087,465.658,-0.406857330322398,0.350732676542563,-1.87
03473836068,4.0812 +no_defs +to +proj=latlong +datum=WGS84
Best regards,
Bart
-----Oorspronkelijk bericht-----
Van: UMN MapServer Users List
[mailto:MAPSERVER-USERS at LISTS.UMN.EDU]Namens Jelmer Baas
Verzonden: woensdag 8 februari 2006 11:45
Aan: MAPSERVER-USERS at LISTS.UMN.EDU
Onderwerp: [UMN_MAPSERVER-USERS] Coordinate Systems used in the
Netherlands?
Hello again,
I have a few questions concerning the projection of my layers in MapServer.
I'm using the StreetPro layers for the Netherlands, and from that
documentation I found that I should use the follows as main projection
in my Map File:
PROJECTION
"proj=stere"
"lat_0=52.15616055555555"
"lon_0=5.38763888888889"
"k=0.999908"
"x_0=155000"
"y_0=463000"
"ellps=bessel"
"units=m"
END
But now I also need to project some seperate TAB files (from MapInfo),
and they are shifted to the North-East. Anyone have any ideas how to fix
this problem? If requested I can post a screenshot.
I tried setting this layer projection to a Dutch system, but I cannot
find which one to use (neither can I find which of them are supported by
MapServer ;().
I tested:
+proj=Netherlands Coordinate Systems -- Unknown Projection ID
+proj=NCS -- Same
+proj=latlong +datum=Rijksdriehoekstelsel -- unknown elliptical
parameter name
+proj=latlong +datum=Netherlands National System -- Same as above.
Can anyone provide me some pointers? I have a beautiful working map, but
with my last layer being off by 50 meters, it's kinda useless.
Thanks!
Regards,
Jelmer Baas
Disclaimer
Aan dit bericht kunnen geen rechten worden ontleend. Dit bericht is
uitsluitend bestemd voor de geadresseerde. Als u dit bericht per abuis
hebt ontvangen, wordt u verzocht het te vernietigen en de afzender te
informeren. Wij adviseren u om bij twijfel over de juistheid of de
volledigheid van de mail contact met afzender op te nemen.
This message shall not constitute any rights or obligations.
This message is intended solely for the addressee.
If you have received this message in error, please delete it and
notify the sender immediately. When in doubt whether this message
is correct or complete, please contact the sender.
