ECW Quality for WCS download
Eijnden, B. van den (Bart) b.vdeijnden at AGI.RWS.MINVENW.NL
Wed Feb 8 07:59:43 EST 2006
Hi Gail,
what kind of requests are you trying? Could you supply an example URL?
In the URL you can specify res_x and res_y and if you give those the same
value as your source data you should get the same quality, at least for us
it seems to work fine like that. We also output to MrSID, ECW and Geotiff
using Mapserver WCS.
Best regards,
Bart
-----Oorspronkelijk bericht-----
Van: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU]Namens
Gail Millin
Verzonden: woensdag 8 februari 2006 13:46
Aan: MAPSERVER-USERS at LISTS.UMN.EDU
Onderwerp: [UMN_MAPSERVER-USERS] ECW Quality for WCS download
Dear MapServer users,
I would like to provide ECW format radar data for download via a WCS (aswell
as Geotiff format). I have managed to get the ECW images to download via WCS
but the quality of the image has been reduced greatly when I compare to the
original image on the server. What could be the reason for this? I would
appreciate any suggestions.
The quality of the GeoTiff's in comparison is the same as the image of the
server, does GDAL work for ECW WCS?
Gail Millin
Geodata Interoperability Support Officer
The University of Manchester
Kilburn Building
Oxford Road
M13 9PL
Tel: +44 (0) 161 275 0581
E-mail: Gail.Millin at manchester.ac.uk <mailto:Gail.Millin at manchester.ac.uk>
Website: http://www.landmap.ac.uk <http://www.landmap.ac.uk>
Disclaimer
Aan dit bericht kunnen geen rechten worden ontleend. Dit bericht is
uitsluitend bestemd voor de geadresseerde. Als u dit bericht per abuis
hebt ontvangen, wordt u verzocht het te vernietigen en de afzender te
informeren. Wij adviseren u om bij twijfel over de juistheid of de
volledigheid van de mail contact met afzender op te nemen.
This message shall not constitute any rights or obligations.
This message is intended solely for the addressee.
If you have received this message in error, please delete it and
notify the sender immediately. When in doubt whether this message
is correct or complete, please contact the sender.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060208/cfd469c7/attachment.html
