Select, Zoom Multiple Items
J. Parapar listario at GMAIL.COM
Wed Feb 8 19:28:05 EST 2006
Hi Lawrence
You can use the ITEMNQUERY mode. You have to set the parameters
QLAYER, QITEM and QSTRING. This can be a bit tricky. Take a look at
http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?MapServerExpressions. The
sintaxis may change depending on the data source.
To center the map try setting the MAPXY parameter to shape.
In the QueryMap section of the mapfile you can set how the features
are highlighted.
Best regards,
Jorge
2006/2/8, Lawrence Hartpence <hartpence_gis at co.jasper.ia.us>:
> Hello.
> I am working with Mapserver 4.6 on a windows 200 server machine running IIS.
> I want to create a form where a user will input 3 different values for 3
> different items on the feature attribute table of a layer.  I want to build
> a query from this input, pass this to Mapserver, have polygons selected,
> then zoom to those selected features.  I don't know mapscript so I would
> like to do this with CGI if possible.  Could someone give me some hints on
> how to do this?
> Thanks!!
> Lawrence Hartpence
> GIS Coordinator
> 101 1st St N
> Newton IA 50208
> 641-792-3084
