Coordinate Systems used in the Netherlands?
mvexel (sent by Nabble.com) lists at NABBLE.COM
Thu Feb 9 09:35:47 EST 2006
Jelmer,
I use NavStreets in a MapServer context on a regular basis in combination
with Dutch topographic data given in RD coords.
I use
	PROJECTION
	  "init=epsg:28992"
	END
in the mapfile root and
		PROJECTION
			"init=epsg:4326"
		END
for the Navteq layers.
The map is then called using RD (Dutch National System) coordinates.
HTH,
Martijn
View this message in context: http://www.nabble.com/Coordinate-Systems-used-in-the-Netherlands--t1082015.html#a2851131
Sent from the Mapserver - User forum at Nabble.com.
