use of Jpeg2000 ?
Ricaille Tanguy
tanguy.ricaille at TRASYS.LU
Thu Feb 9 11:20:29 EST 2006
i use the actual FWTools...
Sorry, but i can't give the image.
Thanks.
Tanguy
----- Original Message -----
To: "Ricaille Tanguy" <tanguy.ricaille at TRASYS.LU>
Cc: <MAPSERVER-USERS at LISTS.UMN.EDU>
Sent: Thursday, February 09, 2006 5:13 PM
Subject: Re: [UMN_MAPSERVER-USERS] use of Jpeg2000 ?
> Ricaille Tanguy wrote:
> > Hi,
> > i have jp2 files in approximately 927*927 pixels in 4 multispectral
bands,
> > coded in 16bits, and i need to provide 500*500 pixels in 3 multispectral
> > bands, coded in 8 bits, as a quick look for this image.
> > I try to use gdal_translate -ot Byte -of JPEG -b 1 -b 2 -b 3 test.jp2
> > test.jpeg, but result is completly black.
> > I have try ather parameter and it is each time the same result.
> Tanguy,
> This looks like it should work, or might give a saturated white result.
> If you add -scale, it should rescale for you too.
> eg.
> But that does not appear to be the issue since you are getting black.
> Could you make your image available for me to try? Also, what GDAL
> build are you using? FWTools? your own?
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam,
> warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | Geospatial Programmer for Rent
