OGR Virtual
Clint Johnson cjohnson at REFRACTIONS.NET
Thu Feb 9 16:25:11 EST 2006
Mark,
You are correct about not needing any projection elements when all data
is of the same projection; however, this is because MapServer will
assume all layers use the same projection
(http://mapserver.gis.umn.edu/docs/reference/mapfile/projection
at bottom under Important Notes).
But for that to happen Mapserver will need to read that projection from
the ciudad layer as ogrinfo clearly stated the following about the
parcel_test layer...
Layer name: PROPERTY_VIRTUAL
Geometry: Unknown (any)
Feature Count: 1
Layer SRS WKT:
(unknown)
Thus it wouldn't hurt to explicitly state the projection.
However, since no errors were produced when creating the map image, I
have a "feeling" that this may be an extent issue.
Look at the map file and your polygon.  Are you *sure* that your
polygon's geometry fits inside of your specified extent?
EXTENT -90.760314 14.252771 -90.210352 14.937117
vs
POLYGON('501453.34 4800585.97,501576.14 4800590.44,501569.85
4800522,501471.61 4800521.63,501453.34 4800585.97')
Cheers,
Clint
Clint Johnson
Refractions Research Inc.
Cjohnson at refractions.net
Mark Adams wrote:
> I will try that. However, my understanding of PROJECTION is that it is
> not
> required unless you have data in more than one projection, or want to
> display the data in a projection different from the one the data is
> in. Is
> that not correct?
> Thanks.
> Mark Adams
> Senior Analyst & Project Manager
> Cuesta Systems (DPRA Canada)
> 5230 South Service Road
> Burlington, ON L7L 5K2
> Phone: 905-333-4544 x14
> Fax: 905-333-0455
> Email: mark.adams at dpra.com
> -----Original Message-----
> From: Emil Zegers [mailto:taatuut at planet.nl] Sent: February 9, 2006
> 3:41 PM
> To: Mark Adams; MAPSERVER-USERS at LISTS.UMN.EDU
> Subject: RE: [UMN_MAPSERVER-USERS] OGR Virtual
> Hello Mark,
> Have you tried adding a PROJECTION to the LAYER containing the ovf file
> and/or the ovf file?
> Something like:
>   LAYER
>     NAME "Virtual Parcel"
>     DEBUG ON
>     STATUS DEFAULT
>     CONNECTIONTYPE OGR
>     CONNECTION "parcel_test.ovf"
>     DATA "parcel_test"
>     TYPE POLYGON
>     # fill projection parameter, e.g. 28992 for Dutch system
>     PROJECTION
>     "init=epsg:12345"
>     END
>     TEMPLATE "null"
>     CLASS
>       STYLE
>         COLOR 255 1 5
>         OUTLINECOLOR 168 112 0
>       END
>     END
>   END
> In the past I had situations where I needed to put the PROJECTION in the
> LAYER and not in the OVF file.
> Also, use STATUS DEFAULT for testing purposes so the layer is always on.
> Regards,
> Emil
> From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU]On
> Behalf Of Mark Adams
> Sent: donderdag 9 februari 2006 21:12
> To: MAPSERVER-USERS at LISTS.UMN.EDU
> Subject: Re: [UMN_MAPSERVER-USERS] OGR Virtual
> Hello,
> I would like to know if there was ever a successful resolution to Frank's
> question below. I am in the same situation: I cannot get the OGR virtual
> layer to render on my map.
> I have had no problem with points. However when I try to render a virtual
> polygon I get no error, just no feature on the map. The other layers all
> render without problem. I get no error from OGRINFO either.
> I've tried a number of different ways of configuring the OVF file, the
> data in the database, and the MAP file. Numerous combinations result
> in "success" in the sense of no errors, but still no features.
> Here is my most recent attempt:
> Connection: I'm using an ODBC connection to an MS Access database. The
> ODBC connection is called "parcel_test".
> OVF:
> <OGRVRTDataSource>
>     <OGRVRTLayer name="parcel_test">
>         <SrcDataSource>ODBC:parcel_test,PROPERTY_VIRTUAL</SrcDataSource>
>   <SrcSQL>SELECT GEOMETRY FROM PROPERTY_VIRTUAL</SrcSQL>
>  <GeometryType>wkbPolygon</GeometryType>
>  <GeometryField encoding="WKT" field="GEOMETRY"/>
>     </OGRVRTLayer>
> </OGRVRTDataSource>
> MAP:
>   LAYER
>     DEBUG ON
>     STATUS ON
>     CONNECTIONTYPE OGR
>     DATA "parcel_test"
>     TYPE POLYGON
>     TEMPLATE "null"
>     CLASS
>       STYLE
>         COLOR 255 1 5
>       END
>     END
>   END
> I've got one record in the PROPERTY_VIRTUAL table, with the GEOMETRY
> value
> set as follows:
> I've also tried storing the geometry without the quotes, brackets, and
> keyword POLYGON but it doesn't change the result.
> I've captured this output when I refresh the map:
> msOGRFileOpen(parcel_test.ovf)...
> OGROPen
> (\\Snow\c_drive\Inetpub\wwwroot\NTGO_GeoPortal\config\..\Data\Shapefiles/pa
> rcel_test.ovf)
> msOGRLayerClose(parcel_test.ovf).
> msOGRFileClose
> rcel_test.ovf,0).
> msDrawMap(): Layer 3 (Virtual Parcel), 0.130s
> msDrawMap(): Layer 4 (Property Parcels), 0.101s
> msDrawMap(): Layer 6 (Streets), 0.030s
> msDrawMap(): Drawing Label Cache, 0.000s
> msDrawMap() total time: 0.281s
> OGROPen
> rcel_test.ovf)
> msOGRFileClose
> rcel_test.ovf,0).
> msDrawMap(): Layer 3 (Virtual Parcel), 0.110s
> msDrawMap(): Layer 4 (Property Parcels), 0.070s
> msDrawMap() total time: 0.220s
> >From the FWTools command line I get this:
> C:\Program Files\FWTools1.0.0a7>ogrinfo ODBC:parcel_test
> INFO: Open of `ODBC:parcel_test'
> using driver `ODBC' successful.
> 1: PROPERTY_VIRTUAL
> C:\Program Files\FWTools1.0.0a7>ogrinfo ODBC:parcel_test PROPERTY_VIRTUAL
> Feature Count: 1
> Layer SRS WKT:
> (unknown)
> OBJECTID: Integer (10.0)
> STATUS: String (20.0)
> UTM_X: Real (0.0)
> UTM_Y: Real (0.0)
> AREA: Real (0.0)
> SHAPE_Length: Real (0.0)
> SHAPE_Area: Real (0.0)
> HERITAGE: String (20.0)
> PAR_UPDATE: String (10.0)
> UPDATE_DATE: String (20.0)
> CREATE_DATE: String (20.0)
> UPDATE_SOURCE: String (50.0)
> AREA_ACRE: Real (0.0)
> PID: Integer (10.0)
> AREA_HECTARE: Real (0.0)
> OGRFeature(PROPERTY_VIRTUAL):0
>   OBJECTID (Integer) = 2
>   STATUS (String) = Active
>   UTM_X (Real) = 501405.687500125
>   UTM_Y (Real) = 4801949.24999883
>   AREA (Real) = 229.843703627485
>   SHAPE_Length (Real) = 77.3317483960398
>   SHAPE_Area (Real) = 229.843703627485
>   HERITAGE (String) = PART V
>   PAR_UPDATE (String) = (null)
>   UPDATE_DATE (String) = (null)
>   CREATE_DATE (String) = (null)
>   UPDATE_SOURCE (String) = (null)
>   AREA_ACRE (Real) = 0.0567943791663515
>   PID (Integer) = 42385
>   AREA_HECTARE (Real) = 0.0229843703627485
> Any help would be greatly appreciated. I have several polygon layers to
> publish this way, ultimately from an Oracle database.
> Thanks in advance,
> Mark Adams
> Fax: 905-333-0455
> On Wed, 21 Dec 2005 00:10:06 -0600, Frank Fica <simbiotico at HOTMAIL.COM>
> wrote:
>> Hello,
>> I've been trying to map a non-spatial postgre table with ogr via ODBC
>> but
> no success. There must
>> be a simple solution to what I'm missing and I haven't been able to
> figure it out. My other layers
>> do render but my Virtual layer doesn't. When I test in ogrinfo I can
> connect but when I try to map
>> in mapserver the image is blank, only my mapinfo layer renders.
>> Does someone has any suggestions on what I'm missing?
>> Here are is my ovf file:
>> <OGRVRTDataSource>
>>    <OGRVRTLayer name="sorento">
>>        <SrcDataSource>ODBC:@PostgreSQL,sorento</SrcDataSource>
>>        <SrcLayer>sorento</SrcLayer>
>>        <GeometryType>wkbPoint</GeometryType>
>>        <GeometryField encoding="PointFromColumns" x="Lon" y="Lat"/>
>>    </OGRVRTLayer>
>> </OGRVRTDataSource>
>> and map file:
>> MAP
>>  IMAGETYPE PNG
>>  SIZE 640 480
>>  UNITS METERS
>>  SYMBOL
>>   NAME "circle"
>>   TYPE ELLIPSE
>>   POINTS
>>    1 1
>>   END
>>   FILLED TRUE
>>  END
>> LAYER
>>  NAME "ciudad"
>>  TYPE POLYGON
>>  STATUS ON
>>  CONNECTIONTYPE OGR
>>  CONNECTION "/var/www/html/guatemala/data/ciudad.tab"
>>  STYLEITEM "AUTO"
>>    CLASS
>>      NAME "Ciudad"
>>    END
>> END
>> LAYER
>>    NAME "sorento"
>>    TYPE POINT
>>    CONNECTIONTYPE OGR
>>    CONNECTION "virtual.ovf"
>>    DATA "sorento"
>>    STATUS DEFAULT
>>    CLASS
>>      STYLE
>>      SYMBOL 'circle'
>>      SIZE 30
>>      COLOR 255 0 0
>>      END
>>     END
>> END
>> END
