SV: [UMN_MAPSERVER-USERS] WFS PropertyIsLike case sensitive
Sture Dingsøyr
candalt at ONLINE.NO
Sat Feb 11 09:13:43 EST 2006
Hi Bart
Thanx for your reply...
I've tested to add the matchCase="false" and it works fine :-)
Since this is not a "OGC standard", is this a feature that will be continued to be supported in Mapserver in the future?
Best regards
Sture
-----Opprinnelig melding-----
Fra: UMN MapServer Users List [mailto:MAPSERVER-USERS at lists.umn.edu] På vegne av Bart van den Eijnden (OSGIS)
Sendt: 11. februar 2006 14:15
Til: MAPSERVER-USERS at lists.umn.edu
Emne: Re: [UMN_MAPSERVER-USERS] WFS PropertyIsLike case sensitive
this is how the OGC spec defines a WFS should operate, it should operate case sensitive by default.
There is a little tweak in Mapserver to get it to behave case insensitive, but it's a mix of WFS 1.0.0 and Filter 1.1 which is strictly speaking against the OGC rules.
If you add matchCase="false" to your PropertyIsLike it should work. Note other WFS 1.0.0 servers won't support this.
More info at:
http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=1381
Best regards,
Bart
Sture Dingsøyr wrote:
>Hi
>I have been testing the WFS FILTER with Mapserver.
>Is it possible to make a property search that is not case sensitive?
>Been testing with this filter, that works fine:
><Filter>
><PropertyIsLike wildcard='%' singleChar='.'
>escape='!'><PropertyName>LOK_KOMM</PropertyName><Literal>AR%</Literal><
>/PropertyIsLike>
></Filter>
>But if i change the "<Literal>AR*</Literal>" to lower case e.g. "<Literal>ar*</Literal>" i get no hits.
>Does Mapserver support case insensitivity in WFS FILTER search?
>I am running on Windows with Mapserver 4.8.1
>Regards Sture
OSGIS, Open Source GIS
http://www.osgis.nl
