MAPSERVER COMPILATION ERROR
Umberto Nicoletti
umberto.nicoletti at GMAIL.COM
Mon Feb 13 08:56:19 EST 2006
Always add the ML to your posts!
What about your server logs'??
Umberto
On 2/13/06, fabio.dovidio at planetek.it <fabio.dovidio at planetek.it> wrote:
> In the map file i have definned
> IMAGETYPE PNG (or jpeg or tiff)
> I have compiled without GDAL\OGR
> Non-working maps is related to only SIZE & IMAGETYPE changes.
> On 13 Feb 2006 at 10:45, Umberto Nicoletti wrote:
> > How's the image format defined?
> > What else (besides size and layers) changes when you switch from the
> > simple to the complex non-working maps?
> > Did you check your server's logs?
> > Regards,
> > Umberto
> > > Anyway I think It' s a compilation error..
> > > sorry, but i don't think u right!
> > > Path is Correct and I have given all necssary permisions..
> > > when I change the output format (png or jpeg or gif...) the error change
> > > but not in positive way...
> > > On 10 Feb 2006 at 17:40, Umberto Nicoletti wrote:
> > > > This is not a compilation error, I'd say the error message is quite
> > > > clear and please do NOT post subjects in upper case.
> > > > Either the path is incorrect or the permissions on the file prevent
> > > > mapserver from opening it.
> > > > Umberto
> > > > On 2/10/06, Fabio D' Ovidio <fabio.dovidio at planetek.it> wrote:
> > > > > Dear list,
> > > > > I have compiled mapserver 4.6.2 under Windows 2000..
> > > > > I have compiled the following libraries :
> > > > > PROJ
> > > > > GD
> > > > > LIBPNG
> > > > > ZLIB
> > > > > REGEX
> > > > > JPEG
> > > > > LIBCURL
> > > > > FREETYPE
> > > > > After compiling I have installed mapserver, following HOW TO..instructions
> > > > > on the web site.
> > > > > When I test the installation the response is OK : "NO QUERY_STRING to
> > > > > decode"
> > > > > The problem is : when I do a request for a simple map file (few layers and
> > > > > limitated SIZE, 100 x 100 or 200x200 pixels) mapserver works fine, but when
> > > > > I do not simple requests (more layers, bigger SIZE, 500 x 500 or 800 x 600)
> > > > > mapserver returns this error :
> > > > > msLoadMap(): Unable to access file.
> > > > > (C:\Inetpub\wwwroot\applicazioni\applicazioni_file\bari_wolf.map)
> > > > > OR :
> > > > > Error CGI
> > > > > The application CGI specified has not returned a complete whole headings
> > > > > HTTP. The following headings are been returned:
> > > > > o/ooPNG
> > > > > In your opinion, WHY ?
> > > > > Thank You
> > > > > Fabio D'Ovidio
> > > > > Planetek Italia Srl
> > > > > via Massaua 12, Bari -70123 Italy
> > > > > e-mail : dovidio at planetek.it
> > > > > http://www.planetek.it
