Query/highlight single or multiple layers
Stefan Schwarzer
stefan.schwarzer at GRID.UNEP.CH
Mon Feb 13 09:34:35 EST 2006
I have a point and a polygon layer. Most of the times only the point
data will be queried, but it can be different too. So, I would like
to limit the highlighting in the resulting map to (sometimes) only
the point layer. But in the moment, when drawing a rectangle it
always highlights the points as well as the polygons.
The doc is saying:
queryByRect( mapObj map, rectObj rect ) : int
Query layer using a rectangle specified in georeferenced map
coordinates (i.e. not pixels). The query is performed on all the
shapes that are part of a CLASS that contains a TEMPLATE value or
that match any class in a layer that contains a LAYER TEMPLATE value.
Returns MS_SUCCESS if shapes were found or MS_FAILURE if nothing was
found or if some other error happened.
//Query the Map
if (!$imgbox)
$map -> queryByPoint($click_pt, MS_MULTIPLE, -1);
else
$map -> queryByRect($click_rt);
So, it gives me the impression that there is no solution to the problem.
Or can someone help me?
Stef
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060213/8303ee5e/attachment.html
