Highlight image symbol
Eijnden, B. van den (Bart)
b.vdeijnden at AGI.RWS.MINVENW.NL
Mon Feb 13 09:50:28 EST 2006
I always draw the selection in a separate LAYER which is on top of the map,
and then you can add a STYLE object to your CLASS with e.g. a circle symbol
and set its color to the color you want for selection. The circle will need
to be underneath your PIXMAP (watch your STYLE sequence).
For that I use PHP/Mapscript.
Best regards,
Bart
-----Oorspronkelijk bericht-----
Van: Xiaonan Zhang [mailto:xnzhang11 at gmail.com]
Verzonden: maandag 13 februari 2006 15:49
Aan: Eijnden, B. van den (Bart)
CC: MAPSERVER-USERS at lists.umn.edu
Onderwerp: Re: [UMN_MAPSERVER-USERS] Highlight image symbol
Hi Bart,
Do you mean I need to add code to draw a circle arount the selected feature?
regards
Jonathan
On 13/02/06, Eijnden, B. van den (Bart) < b.vdeijnden at agi.rws.minvenw.nl
<mailto:b.vdeijnden at agi.rws.minvenw.nl> > wrote:
If your pixmap is transparent, you can draw a circle underneath using the
selection colour.
Best regards,
Bart
Van: UMN MapServer Users List [mailto: MAPSERVER-USERS at LISTS.UMN.EDU
<mailto:MAPSERVER-USERS at LISTS.UMN.EDU> ]Namens Xiaonan Zhang
Verzonden: maandag 13 februari 2006 15:36
Aan: MAPSERVER-USERS at LISTS.UMN.EDU <mailto:MAPSERVER-USERS at LISTS.UMN.EDU>
Onderwerp: [UMN_MAPSERVER-USERS] Highlight image symbol
Dear all,
I created one image symbol (pixmap) to a point layer. However I can not
highlight the selected features in that layer as the symbol is an image.
Is there anyway to solve this?
thanks.
Jonathan
Disclaimer
************************************************************************ Aan
dit bericht kunnen geen rechten worden ontleend. Dit bericht is uitsluitend
bestemd voor de geadresseerde. Als u dit bericht per abuis hebt ontvangen,
wordt u verzocht het te vernietigen en de afzender te informeren. Wij
adviseren u om bij twijfel over de juistheid of de volledigheid van de mail
contact met afzender op te nemen. This message shall not constitute any
rights or obligations. This message is intended solely for the addressee. If
you have received this message in error, please delete it and notify the
sender immediately. When in doubt whether this message is correct or
complete, please contact the sender.
Disclaimer
Aan dit bericht kunnen geen rechten worden ontleend. Dit bericht is
uitsluitend bestemd voor de geadresseerde. Als u dit bericht per abuis
hebt ontvangen, wordt u verzocht het te vernietigen en de afzender te
informeren. Wij adviseren u om bij twijfel over de juistheid of de
volledigheid van de mail contact met afzender op te nemen.
This message shall not constitute any rights or obligations.
If you have received this message in error, please delete it and
notify the sender immediately. When in doubt whether this message
is correct or complete, please contact the sender.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060213/28e8c301/attachment.html
